Vertical or Horizontal Sheathing
   / Vertical or Horizontal Sheathing #1
ETpilot
East Texas
I am into my shed building project. I'm just finishing the wood foundation. I am a solo builder and foundation turned into a challenge. Wood got rain and snow, rare for snow here, and cupped, bowed, warped, etc. I had to manhandle it to get it all square and level. Now I am thinking about the walls whether to sheet the walls vertical or horizontal. Horizontal with a blocking strip would seem the strongest to me. Vertical seems to be the norm for builders. Just curious what others have done. I'm thinking i am going horizontal.
   / Vertical or Horizontal Sheathing #2
I like to stand my sheeting up at the corners. This gives you a little more rigidity then two pieces that are flat, but it's almost like splitting hairs. It's going to be just about impossible to tell the difference between one over the other. The thing that I like about standing them up on a single story building is that the sheeting connects your bottom sill plate to your top plates. This gives you a lot of strength, but I honestly don't know if it's significant over having a seam in the middle of your studs or not.
Either way, you'll be fine.
Eddie
   / Vertical or Horizontal Sheathing #3
Just curious -- do building codes for residential construction have anything to say about this issue?
Steve
   / Vertical or Horizontal Sheathing #4
I've done it both ways. In many cases with a shed, the sheathing may be the siding (ie, using T-111 or similar) so that dictates vertical. If it's a small shed, with some dimensions less than 12', it probably doesn't make much difference either way. The whole shed would blow over in a tornado before any sheathing pops due to an orientation!
Almost all homes I see built nowadays have all sheathing vertical. As Eddie notes, that's probably to make a strong connection between top and bottom plates.
   / Vertical or Horizontal Sheathing #5
A rule i like to use is any wall under 4' in width up and down is best. I did run into an issue once as my state is split into two different wind ratings. We framed a house and the front of the garage had walls under 4' in width and the inspector wanted the sheathing up and down for greater shear strength. I find its easier not to argue with the inspector.
   / Vertical or Horizontal Sheathing #6
FWIW...The Southern Standard Building Code (framing manual) states that if using sheathing at the corners (over let in lateral wood bracing or steel strap bracing)... All the edges of plywood/osb etc. must break on solid lumber with a strict nailing schedule...nails must have full heads (no staples)...
Thanks for the feedback. I read somewhere about horizontal sheathing. Now I cannot find it. Good info here. I will give it more thought.
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
Hose Reel (A53424)
Hose Reel (A53424)
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
7046 (A50322)
7046 (A50322)
Manac Walking Floor Trailer (A50322)
Manac Walking...
