Vertical bush hog idea
/ Vertical bush hog idea #1
musselmark
grand tracadie PE
'05 NH TN75DA
I would like to clear some grown in branches on old roads etc.. What if I mounted a 13 hp horizontal shaft engine inside my front end loader bucket so the shaft was sticking out the side of the bucket. Then mount a bush hog drum/blade to it and have a guard protecting the cab. What diameter blade could a use with 13 hp and do you think this would work.
/ Vertical bush hog idea #2
won't work. Nothing to hold the brush from getting pulled with the blades. On the ground, the roots holds the brush.
/ Vertical bush hog idea #3
Long ago I had a lawnmower that had a front edge serrated or notched to hold taller material. Best weed mower I've ever had.
If you did something like that so the leading edge of a blade covering disk was kind of like a sickle mower, but with a rotary cutter instead of reciprocating, it might work.
Bruce
I don't know the proper name but what are those articulated bush hog things that are on a boom. I see the farmers using them to clear branches from trees around the perimeter of farm fields and dept of highways cutting grass/brush in ditches. They are hydraulic. They have no problem cutting branches. How do they cut.
/ Vertical bush hog idea #5
All those I've seen around here used for cutting branches are flail mowers.
Bruce
PS: I see that Bush Hog has a rotary head available for their boom mower. Says it is for grass and brush. I wonder how it would work in the vertical position.
http://www.bushhog.com/product-line/reach-mowers/boom-mowers.html
/ Vertical bush hog idea #6
Rotary boom mower is what they use around here.. really tears up the trees :)
/ Vertical bush hog idea #7
I would at least use pivoting blades like a bush hog, i once used our Toro as a bushhog and bent the crankshaft when it stalled instantly on a stump. Pivoting blades could have prevented that.
/ Vertical bush hog idea #8
i've seen a sickle bar in vertical mounted on a FEL on youtube or over here... don't remember where :(
/ Vertical bush hog idea #11
I think the sabre samuri is the bucket mounted sickle mower.. I've seen four foot pull behind rotary mowers with 8-12hp engines.
/ Vertical bush hog idea #15
Have to say I hate the roadside appearance when the towns use those boom flails. I guess they save money but what remains looks like heck.
Jim
/ Vertical bush hog idea #16
I made a setup that does this very thing.
I used an 18" circular saw blade powered by a hydraulic motor attached to my home made forks mounted to the fel.
Power is from the power beyond on my 3410, the hoses go to a spool valve mounted to the upright for the fel and then along the arm to the motor driving the saw.
I drilled 2 holes in the saw to mount to a hub made from a chain sprocket with a 1" bore.
looks crude but works really well.
/ Vertical bush hog idea #17
Could/would u post some pictures?
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
Knapheide Service Bed (A61165)
Knapheide Service...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
211298 (A62131)
211298 (A62131)
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
