Valve Clearance
/ Valve Clearance #1
thenorth
Markstay, Ont.
Foton 404
Hi there:
Can anyone tell me the valve clearance on my tractor?
It is a Foton 404, 40 hp, 3 cyl diesel.
thanks in advance guys
John
/ Valve Clearance #2
Please check the engine label and advise what it says. Depending upon the engine, they're typically located on the top of the valve cover, on the side of the valve cover, or on the side of the block (usually under the intake manifold).
//greg//
/ Valve Clearance
thanks greg;
it is a SL3105BT engine, i hope this helps..
john
/ Valve Clearance #4
No problem. Unfortunately I don't know that engine, so we'll have to hope someone pops by that's got the SL3105BT
//greg//
/ Valve Clearance #5
PM or Email Tommy at Affordable Tractors.
I believe he sells this model Foton.
He's a great dealer and I am sure he will help you if he can
/ Valve Clearance
I emailed to affordable tractors, alas, they do not know the required settings.............
/ Valve Clearance #7
If your engine runs in the upper (desirable) temp. range of 180°F to 195°F then .014" for intake and .016" for exhaust.
If your engine runs in the lower range of 140°F to 170°F then .012" for intake and .014" for exhaust.
/ Valve Clearance #8
/ Valve Clearance
Tommy:
I do apologise, I have the email you sent, I guess I got mixed up as I had sent a few queries to diff. people.
I thank you...
John
2008 KOMATSU PC78MR-6 EXCAVATOR (A65053)
2008 KOMATSU...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2016 CASE CX37C EXCAVATOR (A65053)
2016 CASE CX37C...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
