Valve Clearance
/ Valve Clearance #1
thenorth
Member
Markstay, Ont.
Foton 404
Hi there:
Can anyone tell me the valve clearance on my tractor?
It is a Foton 404, 40 hp, 3 cyl diesel.
thanks in advance guys
John
/ Valve Clearance #2
Please check the engine label and advise what it says. Depending upon the engine, they're typically located on the top of the valve cover, on the side of the valve cover, or on the side of the block (usually under the intake manifold).
//greg//
/ Valve Clearance
thanks greg;
it is a SL3105BT engine, i hope this helps..
john
/ Valve Clearance #4
No problem. Unfortunately I don't know that engine, so we'll have to hope someone pops by that's got the SL3105BT
//greg//
/ Valve Clearance #5
PM or Email Tommy at Affordable Tractors.
I believe he sells this model Foton.
He's a great dealer and I am sure he will help you if he can
/ Valve Clearance
I emailed to affordable tractors, alas, they do not know the required settings.............
/ Valve Clearance #7
If your engine runs in the upper (desirable) temp. range of 180°F to 195°F then .014" for intake and .016" for exhaust.
If your engine runs in the lower range of 140°F to 170°F then .012" for intake and .014" for exhaust.
/ Valve Clearance #8
/ Valve Clearance
Tommy:
I do apologise, I have the email you sent, I guess I got mixed up as I had sent a few queries to diff. people.
I thank you...
John
2013 Ford Explorer 4x4 SUV (A64557)
2013 Ford Explorer...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A64553)
2013 Volvo BL70B...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
