Valve Clearance
/ Valve Clearance #1
thenorth
Markstay, Ont.
Foton 404
Hi there:
Can anyone tell me the valve clearance on my tractor?
It is a Foton 404, 40 hp, 3 cyl diesel.
thanks in advance guys
John
/ Valve Clearance #2
Please check the engine label and advise what it says. Depending upon the engine, they're typically located on the top of the valve cover, on the side of the valve cover, or on the side of the block (usually under the intake manifold).
//greg//
/ Valve Clearance
thanks greg;
it is a SL3105BT engine, i hope this helps..
john
/ Valve Clearance #4
No problem. Unfortunately I don't know that engine, so we'll have to hope someone pops by that's got the SL3105BT
//greg//
/ Valve Clearance #5
PM or Email Tommy at Affordable Tractors.
I believe he sells this model Foton.
He's a great dealer and I am sure he will help you if he can
/ Valve Clearance
I emailed to affordable tractors, alas, they do not know the required settings.............
/ Valve Clearance #7
If your engine runs in the upper (desirable) temp. range of 180°F to 195°F then .014" for intake and .016" for exhaust.
If your engine runs in the lower range of 140°F to 170°F then .012" for intake and .014" for exhaust.
/ Valve Clearance #8
/ Valve Clearance
Tommy:
I do apologise, I have the email you sent, I guess I got mixed up as I had sent a few queries to diff. people.
I thank you...
John
2023 Isuzu NPR-HD Mason Dump Truck (A64556)
2023 Isuzu NPR-HD...
John Deere Bird House (A64557)
John Deere Bird...
(2) INTERNATIONAL FERTILIZER DISTRIBUTORS (A64278)
(2) INTERNATIONAL...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
