Valby ch150 questions
   / Valby ch150 questions #1
ricesinice
Hadley, ma
MF 1260
Hi,
I recently purchased a used Valby 150 pto chipper, and it has problems with the belts that I cant figure out. I bought it with the belts broken, and the pulleys rusty, and a new set of belts included. Thinking it just needed the belts replaced, I put the new belts on (not the most fun thing to do) and tried to chip some wood. Well, it took about 10 minutes and 4 smaller trees to burn the belts off. So, purchased 4 new belts, adjusted the anvll to be from about 1/4" space to about 1/30" adjusted the pulleys to be as close to in line with each other as possible, slowed down the feed speed a lot and tried again. Same result, 3 small 3-4" straight just cut maples and one belt broken, 2 others stretched out. I found a couple of small wood chips stuck in the pulleys and was wondering if anyone might think that might be my problem or maybe I am not tightening up the belts correctly? Should I somehow try to clean all of the rust off the pulleys? I don't think that could cause me to throw belts in 10 minutes could it?
I was hoping to be chipping, not wrenching and installing belts all fall.
Thanks for any thoughts
   / Valby ch150 questions #2
Have you checked to make sure that the cutting wheel spins freely with the belts off? You should try and clean the rust off of the pulleys. I'd have to look at my manual but I thought the anvil needed to be really close to the cutters. I'll try and dig it up tomorrow and look it up.
Hi Jim,
Yes the disk spins nice and free. After the first time throwing/stretching the belts, that was one of the things we checked. It is supposed to be 1/30" and it was probably about 1/4". We adjusted now so it is really close. After the first log, I could smell the belts were having a hard time.
   / Valby ch150 questions #4
I would expect that your machine has a shear bar that the knives go past where you are measuring your clearance.
The shear bar edge has to be sharp and square, many shear bars can be rotated and flipped end for end to get to a new square surface.
Also many will have adjustment studs to allow them to be squared with the knives.
OK,looked at that manual you don't have a shear bar. You do have what they call anvils,
if they are rounded over or chipped it will cut hard and possibly slip your belts.
   / Valby ch150 questions #5
Hi Jim,
You got the right clearance. Make sure you have your RPM's up there as per this manual. I run mine at PTO speed. Make sure the belts are tight and the cutters sharp. I sharpen mine on a surface grinder at work. They will cut your finger right off with very little difficulty. Here is the manual for yours. https://storage.googleapis.com/wzukusers/user-34463188/documents/5bd223202af4cc8xK39a/CH150.pdf
   / Valby ch150 questions #6
Does the system spin freely with the belts assembled? Maybe it's the bearings that the pulleys spin on. What about any idler pulleys? Do all the pulleys that the belts ride on run straight & true?
Maybe worn bearings or shafts. With tightened belts the shafts/bearings could be pulled out of alignment and binding.
Bearings are a thought. Everything spins nicely though and feels nice and smooth. Under no load and the pto running, all sounds fine. I did notice that the anvil I had adjusted to about 1/30" had moved out to about 1/4" clearance. but, there was not any debris wrapped around the disk to cause any extra load on the belts. The 2 pulleys seem to be lined up pretty nicely, maybe 1/8" out front to back but, but, I cant adjust the pto pulley any more to get it just perfect.
So, no one has had any problems with small chips getting into the pulleys? I had to dig a few out that got wedged in there pretty hard from the belts??
I have another set on order and they will hopefully be here tomorrow, 3rd set of belts and about a wheelbarrow of chips!
   / Valby ch150 questions #8
Hi, I have a Valby CH150. Built like a tank, but I know what you mean about changing belts...NOT easy. I've only done it once. It is due for another set soon.
I don't have a problem with chips getting into the pulleys. Do you have any problem with chips getting stuck on the flywheel and smoking or basically starting to burn? That is the only complaint I have about the chipper. Thanks
Bob
To be honest, I don't know why the belts are smoking, stretching and breaking. I am thinking it is from the chips getting into the pulley then causing the belt to stretch and break but, at this point it is only a theory. I did run it for a while the last time without putting anything through it and all seemed fine. So, you get chips in the pulley but, they don't cause a problem except for causing fires occasionally? I am thinking about buying a fish scale to try to get the belt tension somewhere in the ballpark of specs.
   / Valby ch150 questions #10
Maybe I wasn't clear in my explanation. I don't get chips in the pulley. I get chips stuck on the lip of the flywheel or disc that the knives attach to.
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
1265 (A50490)
1265 (A50490)
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
Walinga Agri-Vac (A50514)
Walinga Agri-Vac...
