UTV at 8600 ft?
/ UTV at 8600 ft? #1
Jchonline
Elite Member
Red Feather Lakes, CO
Kubota L6060, KX040-4, M7060, X1100C, M62(S)
Hi Everyone,
We are in the market for a UTV (2 seater not 4) for our mountain property. We have 47 forested/rocky acres with some hills and are at 8600 ft. At a minimum I want a cab and heater. We will be using it as a snow plowing machine in the winter for our 1/4 mile of disintegrated granite road (with some hills), moving wood/rocks, and helping get to more difficult places a truck cannot.
My first thought was a Kubota RTV 1100C, but I am concerned about a diesel with no turbo at our altitude. Previous experiments with non turbo Diesel engines on tractors didnt go so well. The Sidekick was my next option, but they dont have a good plow option (at least from Kubota). It is basically an ATV plow with mechanical angle.
This needs to be a UTV, no trucks or jeeps. They are too big to get places on our property. So what does everyone think?
/ UTV at 8600 ft? #2
I read good things about the Gator diesel with the add-on turbo kit. I think it was about $2k.
/ UTV at 8600 ft?
I appreciate the comment. If this is something JD installs and warranties then I will consider. If it is like any of the others, it is aftermarket and voids warranties. That would not be favorable for me.
/ UTV at 8600 ft? #4
1000cc gas so HP should not be a problem......tracks optional
/ UTV at 8600 ft? #5
Have you considered a model with fuel injection?
/ UTV at 8600 ft?
I am hesitant to go gas for the loss of low end torque, and the belt driven transmission. Pulling small trees out of a stand doesnt sound like something appealing to these machines. However I could be wrong.
/ UTV at 8600 ft? #7
Sounds like you need a Toolcat...
/ UTV at 8600 ft? #10
These is nothing wrong with CVT transmissions. We tow snow implements with them for thousands of hours, at high percents of the engines max HP. I've operated grain combines with a CVT drive. If you get a large CC engine, I'd bet donuts you'll do fine at 9000 ft.
Let me add that hydrostatic transmissions failed, in the world of snow grooming.
/ UTV at 8600 ft? #11
Would you be surprised if I mentioned the Gator 825i has more low end torque than the Gator 855D - Diesel? Both are CVT driven.
/ UTV at 8600 ft? #12
What Snow groomer do you operate?
/ UTV at 8600 ft? #14
I have extensive experience with Tucker in the Rocky Mountain West.
/ UTV at 8600 ft? #16
I have a Polaris Ranger 900 that I use up at my cabin at 10k feet. It does fine. The gearing has a much bigger impact on these machines than the power numbers.
I remember you being overly concerned about not having a turbo up high in elevation. I have a few pieces of diesel machinery without a turbo and they do just fine up there. Remember, up at this altitude, the air is thin. Although a turbo helps, you really have to put on a big turbo to get the mass of air needed to reap the benefits. Then the machine would be super laggy until the turbo spooled up enough. Most turbos sized to the machine can't get enough oxygen molecules crammed in the motor to really achieve full fulling, your always leaving some fuelling on the table. The computer measures the mass of air over a sensor and adjusts fuelling based on that reading. That is why having a non turbo motor at high altitudes actually gets to full fulling and I would say makes comparable power. Now if you can get a tune to adjust the fulling independent of the mass air flow sensor, then it's a non issue. You would just be burning a lot of diesels at that point and making a black cloud.
Just remember the physics of how a diesel operates and the three inputs needed for it to run: Air, Fuel, Compression.
/ UTV at 8600 ft? #17
I'd suggest the OP looks at the models his area dealer sells. In our book, its about good service, as much as whatever brand the machine is.
/ UTV at 8600 ft?
Mind sharing which machines you are seeing that kind of reliability in?
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2015 Ford F-150 Ext. Cab Pickup Truck (A66736)
2015 Ford F-150...
2019 Nissan Versa Sedan (A66738)
2019 Nissan Versa...
25057SFL (A64557)
25057SFL (A64557)
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
2027 . . (A67714)
2027 . . (A67714)
