Utility box for 3p hitch
/ Utility box for 3p hitch #1
Einar Kr
Iceland
Kubota M125X
I m planing on building a utility box for 3p hitch. I m thinking of a box which to use as ballest, carrying and so on. The things I m mainly hauling around are fencing tools, fence posts, fencing material, shovels, rakes and so on. I m also thinking of using the box to hook up the fence wires for reeling them out....so in other words, a utility/swiss army box for all round carrying and fencing. So I seek to you good folks for some ideas and hopefully pictures of similar projects.
/ Utility box for 3p hitch #2
How about a Jobox and add a hitch to it? It is on my list to setup.
Steve
Jobox is not to my knowledge sold in Iceland and utility boxes sold here are not cheep and the quality of the ones in my price range are not to my standards but a good idea all the same
/ Utility box for 3p hitch #4
get a carry-all and bolt a good pallate to it. carries rools..or you can stack ballast on it.
soundguy
/ Utility box for 3p hitch #5
Mount the pins high enough on the sides so you can lower it to the ground when you want to drop it. This will also act as a parking brake.
Install a 2" (or what-ever is standard in Iceland) receiver on the rear for a trailer hitch/winch/tow hook/etc
Have a block on the bottom so you can rock it slightly while trying to re-connect the top link.
Have it heavy
/ Utility box for 3p hitch #6
Have a look on Ebay for "link box" or "transport box" & look at some pictures. Fleming do a useful tipping one.
/ Utility box for 3p hitch #7
Hi Einar Kr,
I made some ballist boxs and they turned out good. They sure work nice for so many things. I don't know how to link you to the pictures I posted. The only way I can tell you to see them is to click on my name,look at my profile and look at find all threads started by me.
Maybe this well give you some ideals. You can add to it for what ever you are going to use it for.
Lee
/ Utility box for 3p hitch #8
Hi Einar Kr,
Lee
Here it is.
http://www.tractorbynet.com/forums/build-yourself/141747-my-ballast-box.html
I remember seeing that before.....and that's a nice box!
/ Utility box for 3p hitch #9
johndeere4300, How did you do that?
/ Utility box for 3p hitch #10
I have a all purpose utility box on the front end instead of 3 pt rear end.
/ Utility box for 3p hitch #11
/ Utility box for 3p hitch #12
That's a nice utility box!
You should have a thread on that....If you have the pictures when you first started building it.
That would be handy around here....I really like it.
Thanks for sharing!
/ Utility box for 3p hitch #13
It's a simple design....
A 4'x6'x3' metal cage supported by the fork lift which slide into 1'x4' metal tube cross the bottom.
The gate opens towards the front flat with the floor so it become a 6'x7' working platform.
The box has short leg on each bottom corner so it can be left sitting on flat ground.
Here is another pic.....
/ Utility box for 3p hitch #14
That's a very good setup!
My wife would want to use that so she could pick apples, pears & cherries:D
Thanks for the picture!
MASSEY FERGUSON 28 BLADE DISC HARROW (A64278)
MASSEY FERGUSON 28...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
