Using existing switch for power
/ Using existing switch for power #1
George in Spokane
It's probably old news to most people but I came up with a way to get accessory power with minimal cutting of wires.
I needed 12V to run my new sprayer. I could have spliced but I ended up just disconnecting one rear light at the plug and crimping on a connector for each wire. The wires were easy to get to since the underside of the fender is exposed. I never go off my land so I do not need rear lights.
This way I can use my headlight switch to control the sprayer. Somehow it feels more "stock". It is also a very short run to the 3pt implement.
/ Using existing switch for power #2
I think that's a bad idea. You may very well burn-up the switch, it was designed to turn a light on&off, not a pump motor. It would be best to add a new circuit from the battery through a heavy duty switch or a relay.
/ Using existing switch for power #3
Fleet Farm sells a in line switch to run a FEMCO Sprayer. I got one for my tractor, it plugs into the cig lighter and the pump pigtail, there is enough wire to go from the tractor seat to the drivers seat to the pump.
Thanks for the warning but the pump only draws 9.3 amps. I disconnected the headlamps so I imagine the pump draws less than the two front lamps and the one rear light.
/ Using existing switch for power #5
For running current you're right on the edge. Assuming 2 55w headlamps they will draw 9.1A at 12V. Your pump is 9.3A so in that aspect you're ok. However what's the stall current of the pump. Hopefully your fuse will blow before damaging the switch. Other than that I don't see any major problem.
/ Using existing switch for power #6
Not just the stall current, a bigger problem may be the starting current which can be several times the running current. Also remember DC is much tougher on switches than AC (arcing).
Andy
/ Using existing switch for power #7
I have been running a sprayer pump on my headlite switch for 15 years on two different tractors. Never had a problem.
But then again I guess it depends on the pump.
/ Using existing switch for power #8
That is the jist of it "depends on the pump". Another is the quality of switch. I think that a switch made 15 years ago will be a much better quality than the cheap ones made nowdays.
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2024 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2024 B and B...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
2022 EZ-GO ELITE...
2016 PETERBILT 365 DAYCAB (A63569)
2016 PETERBILT 365...
