Using DR PTO trimmer on Cat 2 Tractor?
/ Using DR PTO trimmer on Cat 2 Tractor? #21
Curious how this DR mower would stand up to use. Looks almost more hobby farmer than for use on mowing miles and miles of fence. Also if it can take down thick grass that you might get to once a year, not the 2 or 3 inches of green grass that is shown in the video. The trimmer head that holds the line looks to be plastic?
It looks like the same head they use with their walk-behind string mowers. The ball lasts for years with heavy use, even though it is some sort of plastic. With the heavy cord they cut small saplings, as long as you get them the first year and don't let them get woody. Woody stems over about a quarter inch in diameter generally break the strings unless you ease into them very gently, and even then quickly shred the strings.
The walk-behind units cut three-foot grass and weeds with no problem. But on this one I wonder how the round shield that steers it around the fence posts works with tall stuff, since the string is actually under the shield. I'd think it would bend over taller weeds and make them harder to cut.
Terry
/ Using DR PTO trimmer on Cat 2 Tractor? #22
OK, I now officially hate you guys.
I have been eyballing and lusting after a weed badger for years now.
This thing is even better, because it is much more simple, and dosn't rely on hydraulics and discs.
IF it can be adjusted, so the head tension is light enough, it could be used in Vinyards and blueberry fields, to clean out the tough to kill crap growing between bushes.
The BIG question is, will it put up with bieng used, for more than just spiffing up a 1/2 A fenceline twice a year.
Will it cut blackberry canes and young sumac?
I hope so.
The thing would save me a couple K in herbicides, and another couple K in labor annually, if it can.
/ Using DR PTO trimmer on Cat 2 Tractor? #23
I find DR equipment all or nothing. I returned the two wheel line trimmer with off set head feature. While it worked a heavy hand held line trimmer worked better for me. Now our DR Brush and Field mower stays in the shed more than not but has gotten a work out this year. Just this evening we got it out and mowed a neighbors yard with the 30" bush hog head. It was as wide of a mower that would have worked well and it was way too thick/talk for any lawn mower even the 30" Snapper that we used in some of the yard because it had not been mowed this year and he had a stoke and hopes to get out of the hospital next week.We have a 42" mower deck that fits it too. New it is nearly $4500 bit we got ours from a guy in stone mountain GA for $1400. Most see little use and are seldom worn out even if 20 years old.
/ Using DR PTO trimmer on Cat 2 Tractor? #24
what I'd like is a trimmer like that which can mount on my RD mower ...a dedicated belt, maybe, with an electric clutch engagement so that when I'm mowing, I can engage and trim ...without have to return to base and switch implements...
Anyone know why DR lists a minimum of 25 HP tractor for their 3 pt model when they have the same 22" size cutting head on walk behinds with much smaller engines? Would you really need 25 HP?
It does seem a bit high, though of course you need some of that horsepower to move the tractor. One of the phone reps did describe the company as being "very conservative" with their published requirements.
The BIG question is, will it put up with being used, for more than just spiffing up a 1/2 A fenceline twice a year.
It'll be more than a month before I can provide any firsthand information on this. But like you I appreciate the simplicity of the design. It seems as though that should contribute to reliability. The belt can easily be replaced. And aside from the trimmer head you wouldn't think anything else is particularly prone to failure.
The original print ad I saw for this trimmer referred to a 6-month trial. I found the fine print here. It's for non-commercial use, otherwise only 30 days. The freight charge for returning 220 pounds will set you back some, however.
/ Using DR PTO trimmer on Cat 2 Tractor? #27
How is it working out?
/ Using DR PTO trimmer on Cat 2 Tractor? #29
Just received the shipping notice today. It says two to seven business days...
Thank you, I am looking forward to hearing how it works in the real world with grass that can be as tall as the fence and thick. Right now I have it on my "wish list subject to more information"
/ Using DR PTO trimmer on Cat 2 Tractor? #30
Same here. Would fit nicely on the BX2660 or the B7500 if it can handle heavy grass. I have used the Swisher self powered version before and it did well.
Aaron Z
/ Using DR PTO trimmer on Cat 2 Tractor? #31
Looking forward to the review.
What are you mounting the thing on?
:confused3:
With this trimmer on the way I put off weed-eating my pasture fence, so the grass is quite tall. I'll let you know how it works. The freight company left a message saying it'll come Monday or Tuesday.
It arrived today, but I'm in the middle of other projects so it'll be some days before my initial report. As you can see it comes in a big box on a pallet. The freight company docs say it's 311 pounds.
/ Using DR PTO trimmer on Cat 2 Tractor? #35
It arrived today, but I'm in the middle of other projects so it'll be some days before my initial report. As you can see it comes in a big box on a pallet. The freight company said it's 300 and some pounds.
No problem, take your time. Was there a pic you intended to attach?
DR PTO trimmer: Generally good first impression
I assembled the DR trimmer yesterday and plunged right into some challenging conditions. Here's what the open box looks like:
The assembly was pretty simple, with just a few main pieces, including the three-point bracket, wheel, PTO shaft and trimmer body. The latter is the heavy part, but I was able to move it around by hand, though DR recommends having two people. Everything feels pretty solid and sturdy. The first possible (small) negative I encountered is the wheel:
It's pneumatic, meaning possible extra maintenance with inflation. I'd have preferred solid, but maybe this will hold air better and longer than some tires I've had.
Here's one end of the three-point bracket, on which I've installed a ball with Cat 2 adapter bushing:
The PTO shaft connects to the gear box in a way I haven't seen before. Instead of a shear pin there is a key that protrudes from a cutout in the gear box shaft. A groove on the PTO shaft connecter slides around the key. A little 4 mm set screw is used to keep them together. I was skeptical of this. I made it as tight as I could with a T-handle wrench, but sure enough, about when I was finishing my test run, the PTO shaft popped off. Fortunately the key stayed in place, otherwise I'd be hard pressed to find it. Next time I will try an L wrench, which may give me more torque. Also, the manual suggests using Loctite if you'll be leaving things connected for longer periods. By the way, the manual is excellent: clear, well written, and with plenty of illustrations.
After mounting and assembly you should really take the time to adjust your hitch properly. I didn't, so I ended up testing and fiddling for a while until I finally had things about right. There are two modes of operation, which are selected by putting a long bolt in one of two holes. Sorry, don't have a picture of this. In one case the rotation of the trimmer about the tractor's long axis is limited. This is for trimming where the trimming area is in the same plane as the tractor's wheels. The other setting is for ditches and such. This allows for up-and-down rotation. I haven't tried the latter yet.
I used the blue .175 line, of which three pairs were included. There were also some pairs of the green .155 line. The manual suggest using the smallest line you can for the conditions.
After the adjustments were made I opted for trial by fire, heading right for my pasture fence, which hasn't been trimmed in over a year. The grass and weeds were two to three feet high. There were also some saplings in there, which I assume contributed to reduced string life. I made it about a quarter mile in each of two runs before the strings disappeared. You're supposed to stop immediately if one string breaks, but I found it hard to detect when this occurred, instead seeing that I was just knocking the grass down rather than cutting it after both strings when AWOL. I did find one string, which appeared to have broken at the trimmer head.
The biggest problem I had comes from an engineering tradeoff. On the one hand, I appreciated that the swing-arm spring tension wasn't high enough to cause problems with my T-posts during head impact. On the other hand, the lower spring tension means that denser grass and weeds tend to push the arm away from the fence and back behind the tractor. This was even worse at the top of my pasture where gravity was also pushing the trimmer away from the fence. The solution may consist of clearing the other side of the fence so I can trim from the high side, and of course trimming more frequently so the plant growth is less dense.
Here are a couple pictures of better results on flat ground:
The wheel axle tends to accumulate grass, which wraps tightly around it:
So there you have my first impression of the DR PTO string trimmer. In spite of it's limitations I think it has the potential to reduce the labor in fence line maintenance. It appears to be well made, and it's relatively easy to use.
/ Using DR PTO trimmer on Cat 2 Tractor? #38
I don't have the DR trimmer but looking at your pictures, I will comment on one thing: Whether I use a wheeled trimmer or a hand held one, things go a lot better if I first mow along both sides of the fence with the lawn mower (B2710 mmm). That reduces the work for the string trimmer and gives the cut material a place to go rather than forcing the string trimmer to battle it's way through grass it already cut. YMMV
I usually mow one or both sides before trimming, but in this case I just wanted to try the new trimmer, so include that in the "challenging conditions" I mentioned.
/ Using DR PTO trimmer on Cat 2 Tractor? #40
Interesting thread.
Does part of the setup include tilting the cutting head down toward the front, like a bush hog, so that only the leading edge of the cutter contacts the grass?
Aluminum Turtle (A65583)
Aluminum Turtle...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
10ft. Barge Box Wagon with Hoist (A65640)
10ft. Barge Box...
2007 KENWORTH (INOPERABLE) T880 (A65643)
2007 KENWORTH...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
