Using an offset flail mower to mow grass
   / Using an offset flail mower to mow grass
MechMaxx told me the maximum cut height is 2”. I want the cut height to be 3”.
Is there a way to accomplish that?
   / Using an offset flail mower to mow grass #12
Boy Don, I learned something today; that leaves me out of buying one, I cut my lawn @ 4" and fields @ 8".
   / Using an offset flail mower to mow grass #13
AFAIK operation of a flail is designed to ride on the ground on the big steel roller, at least that's how mine works. At that point it's weight is only a concern during transport. That weight is also very "close in" in comparison to a rotary mower.
I wouldn't have a concern at all with your tractor.👍
I have a heavy 8' brush mulcher, at least that's what I think FAE (the manufacturer) calls it with heavy hammers for the cutting and a hydraulic offset. There's nothing on it thinner than 1/4" plate.
It "feels" very much lighter than my 8' dual spindle Bush Hog which I attribute to its distance beyond the rear axle.
My cutting height is changed by removing 2 bolts. One on each side and the big roller hinges down/up on a trailing arm type assembly. I would think that you might be able to get a little higher cut but not without a little fabrication.
   / Using an offset flail mower to mow grass #14
Not a great picture but I found one on my phone.
Might as well show you the view from this guys place.
I cut it once a year for him and he was very generous paying me to use the flail over my rotary.
   / Using an offset flail mower to mow grass #15
I looked seriously at the Mechmaxx and it was the short height max cut that drew me away, for my intended purposes. I loved everything else about it. It was not the offset though, don't forsee me needing it.
   / Using an offset flail mower to mow grass #17
The Bestco mower will easily leave 4". Simply adjust the tilt to the desired cut height.
That seems reasonable. Lengthen the top link to pivot the mower back.
   / Using an offset flail mower to mow grass #19
I forgot about that👍
I only use it once a year on that place. I built a hydraulic top link year's ago and it's very handy with the flail.
   / Using an offset flail mower to mow grass #20
The Betsco 68" can cut to a 6" height. There is an adjustment on the roller.
2013 Chrysler Town and Country Van (A56859)
2013 Chrysler Town...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2011 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2011 GALYEAN 130...
