Using a Rear Remote for 3rd Function
/ Using a Rear Remote for 3rd Function #1
BCrouse
PA
Kubota MX5200
I have seen people use a 3rd function valve to run a hydraulic top link.
I would imagine there are folks out there doing the reverse of that and using a rear remote for a 3rd function purpose.
Though the lines would be long, is there anything that would stop me from using a rear remote to run a grapple?
/ Using a Rear Remote for 3rd Function #2
I think it's fairly common.
I would think so too, but I cannot find a lot of literature on it. Perhaps I am searching the wrong terms.
/ Using a Rear Remote for 3rd Function #4
Not rocket science just make the hoses long enough to reach the rear remotes then use the remote lever to control the cylinder.
I didn't think it was. Just confirming.
/ Using a Rear Remote for 3rd Function #6
Its somewhat awkward but it works. We cleaned out about 1,000 old hay bales from a shed last. Winter with a neighbors grapple mounted on the front of my Kubota L5740 with long hoses running from the rear remotes to the grapple.
/ Using a Rear Remote for 3rd Function #7
It's what I'll do once I get a grapple. Cheap solution, though maybe not best solution.
/ Using a Rear Remote for 3rd Function #8
I run mine that way. It would be easier with a fancy joystick controller but not $1,000 easier.
Jim
/ Using a Rear Remote for 3rd Function #9
I have been running mine for some time in this manner. You can read about it in the links below. I am fortunate that on my Kioti, the factory rear remote control valve lever is conveniently located to be operated with you hand on the main joystick by lengthening the lever about 4 inches.
Not only do I have no desire for a 3rd function setup because of the money, I don't believe I would even bother to install if it was given to me. I would just sell it. I am that happy with my Rear Remote extended lever operation.
http://www.tractorbynet.com/forums/...extension-control-valve-lever.html?highlight=
http://www.tractorbynet.com/forums/...nnects-loader-torque.html?highlight=hydraulic
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
1975 Bomag MPH1 Reclaimer Mixer / Soil Stabilizer (A61572)
1975 Bomag MPH1...
Towable Generator (A60352)
Towable Generator...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
