Using a Rear Remote for 3rd Function
/ Using a Rear Remote for 3rd Function #1
BCrouse
PA
Kubota MX5200
I have seen people use a 3rd function valve to run a hydraulic top link.
I would imagine there are folks out there doing the reverse of that and using a rear remote for a 3rd function purpose.
Though the lines would be long, is there anything that would stop me from using a rear remote to run a grapple?
/ Using a Rear Remote for 3rd Function #2
I think it's fairly common.
I would think so too, but I cannot find a lot of literature on it. Perhaps I am searching the wrong terms.
/ Using a Rear Remote for 3rd Function #4
Not rocket science just make the hoses long enough to reach the rear remotes then use the remote lever to control the cylinder.
I didn't think it was. Just confirming.
/ Using a Rear Remote for 3rd Function #6
Its somewhat awkward but it works. We cleaned out about 1,000 old hay bales from a shed last. Winter with a neighbors grapple mounted on the front of my Kubota L5740 with long hoses running from the rear remotes to the grapple.
/ Using a Rear Remote for 3rd Function #7
It's what I'll do once I get a grapple. Cheap solution, though maybe not best solution.
/ Using a Rear Remote for 3rd Function #8
I run mine that way. It would be easier with a fancy joystick controller but not $1,000 easier.
Jim
/ Using a Rear Remote for 3rd Function #9
I have been running mine for some time in this manner. You can read about it in the links below. I am fortunate that on my Kioti, the factory rear remote control valve lever is conveniently located to be operated with you hand on the main joystick by lengthening the lever about 4 inches.
Not only do I have no desire for a 3rd function setup because of the money, I don't believe I would even bother to install if it was given to me. I would just sell it. I am that happy with my Rear Remote extended lever operation.
http://www.tractorbynet.com/forums/...extension-control-valve-lever.html?highlight=
http://www.tractorbynet.com/forums/...nnects-loader-torque.html?highlight=hydraulic
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2004 John Deere 310SG 4x4 Extendahoe Loader Backhoe (A61572)
2004 John Deere...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2017 Chevrolet Cruze Sedan (A61574)
2017 Chevrolet...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59912)
2025 ALCOM XPRESS...
Generator (A61572)
Generator (A61572)
