Using a Rear Remote for 3rd Function
/ Using a Rear Remote for 3rd Function #1
BCrouse
PA
Kubota MX5200
I have seen people use a 3rd function valve to run a hydraulic top link.
I would imagine there are folks out there doing the reverse of that and using a rear remote for a 3rd function purpose.
Though the lines would be long, is there anything that would stop me from using a rear remote to run a grapple?
/ Using a Rear Remote for 3rd Function #2
I think it's fairly common.
I would think so too, but I cannot find a lot of literature on it. Perhaps I am searching the wrong terms.
/ Using a Rear Remote for 3rd Function #4
Not rocket science just make the hoses long enough to reach the rear remotes then use the remote lever to control the cylinder.
I didn't think it was. Just confirming.
/ Using a Rear Remote for 3rd Function #6
Its somewhat awkward but it works. We cleaned out about 1,000 old hay bales from a shed last. Winter with a neighbors grapple mounted on the front of my Kubota L5740 with long hoses running from the rear remotes to the grapple.
/ Using a Rear Remote for 3rd Function #7
It's what I'll do once I get a grapple. Cheap solution, though maybe not best solution.
/ Using a Rear Remote for 3rd Function #8
I run mine that way. It would be easier with a fancy joystick controller but not $1,000 easier.
Jim
/ Using a Rear Remote for 3rd Function #9
I have been running mine for some time in this manner. You can read about it in the links below. I am fortunate that on my Kioti, the factory rear remote control valve lever is conveniently located to be operated with you hand on the main joystick by lengthening the lever about 4 inches.
Not only do I have no desire for a 3rd function setup because of the money, I don't believe I would even bother to install if it was given to me. I would just sell it. I am that happy with my Rear Remote extended lever operation.
http://www.tractorbynet.com/forums/...extension-control-valve-lever.html?highlight=
http://www.tractorbynet.com/forums/...nnects-loader-torque.html?highlight=hydraulic
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
