Using a metal snake on ABS plastic drain pipe?
   / Using a metal snake on ABS plastic drain pipe? #11
That's where I usually have trouble --- the straight piece between the sink and the trap.
   / Using a metal snake on ABS plastic drain pipe? #13
Also, there's toilet plungers and sink plungers. Use a sink plunger. Toilet plungers look like this...
Moss, have you ever broken any pipes or caused leakage at fitting joints with your method? That seems to put a lot of pressure on the fittings?
I've never heard of a sink plunger ... just a toilet plunger?
The toilet seems to flush fine, the shower drain is a little slower than it used to be. A sink full of water can take an hour or more to drain. But when I took apart the P-trap I didn't see any restriction including when I examined the pipe after the P-trap.
   / Using a metal snake on ABS plastic drain pipe? #15
I've never popped a pipe with a plunger. I don't do snakes. That's up to the plumbers. Although I do occasionally use the 2' long plastic zip strip drain snakes. They'll grab a lot of hair out of the drain plug. Like these:
Did you remove the drain plug in the sink and look down into the sink drain and see light when you had the P-trap off? As other's have mentioned, there can sometimes be a huge blockage of hair and bath products stuck on the lever that lifts the plug.
   / Using a metal snake on ABS plastic drain pipe? #16
Also, don't skip trying a chemical drain cleaner. I have two daughters with extremely long, fine, blonde hair. When they were kids, it was down past their knees! So we had quite a few hair clogged drains. The bathtub drain, especially, but the sink drains, too. When they brush their hair, a surprising amount ends up down the sink drains.
I like to use the two-part gel-type liquid drain cleaner. It works most of the time. Liquid Plumr seems to work very well.
Liquid-Plumr(R) Clog Destroyer + Urgent Clear™ For Clogged Sinks
   / Using a metal snake on ABS plastic drain pipe? #17
But that is only at home. I don't use the chemical at my job. Just remove the sink drain plug, clear any hair and gunk from that, then plunge the sink. 5 minutes and you're on to the next one.
I have a septic system so chemical cleaners cannot be used.
Another person suggested a large quantity of near-boiling water into the sink drain might clear any residual soap clogged into hair along the sides of the pipes. I have never tried that either.
   / Using a metal snake on ABS plastic drain pipe? #19
I have also used the microbial liquids used in campers. It takes a few applications over a couple days but it works to clean the pipes.
   / Using a metal snake on ABS plastic drain pipe? #20
I have a septic system, too. Liquid Plumr says its safe for septic systems. However, I understand your concerns, so try the plunger trick. Can't hurt, and a small sink plunger is only a few bucks. The zip strips are 3 for $2.99.
But be sure and pull that sink stopper out and look down there before doing anything else. It might be just right there, before the P-trap.
Giyi Mini Side Shift Forks (A53316)
Giyi Mini Side...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2006 Deere 410G (A53314)
2006 Deere 410G...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
