Using a Kubota to Power a Generator for Extended Periods
   / Using a Kubota to Power a Generator for Extended Periods #31
   / Using a Kubota to Power a Generator for Extended Periods #32
if the power unit were installed in a marine application, it may run continuously for several weeks. with lives depending on it.
   / Using a Kubota to Power a Generator for Extended Periods #33
If I had money, I wouldn't buy a Jag or Lamborgini . I would scour the planet for a nice original Lister. These poor quality clones are probably not worth the little they are asking. And a real crap shoot.
   / Using a Kubota to Power a Generator for Extended Periods #34
I thought you couldn't buy India Listers anymore due to the EPA banning the import of them???
   / Using a Kubota to Power a Generator for Extended Periods #35
So anyone get to use their Genny last night or today?
I was about to go hook mine to the well when duke got the electrons running back and forth again. ;)
   / Using a Kubota to Power a Generator for Extended Periods #36
The Listers are being brought in as "Compressors". In Canada, anyway.
Many feature cardboard shims.
   / Using a Kubota to Power a Generator for Extended Periods #37
   / Using a Kubota to Power a Generator for Extended Periods #38
I guess we are just fortunate here in Ea WA. The longest outage in the 34+ years I've been here was 28 hours. Hardly worth even the thought of standby power.
I do have a 3000 watt Honda but its used to power my tools when I'm out on the property. A friend worked on one of those big factory boats up in AK. They catch & process cod. Their diesel engines run 4+ months, non-stop, keeping the boat & refrigeration going. Once a commercial fishing boat leaves port - it will normally only shut down the diesel engine if there is a problem.
   / Using a Kubota to Power a Generator for Extended Periods #39
I just bought a yanmar ydg5500 portable and wired into the house with a gen inlet box. Probably took 3 hours to do. I bought it off of Craigslist for less than half brand new.
If i were to keep my tractor at my primary residence, i would have absolutely no problem running a pto genny for days. My B2920 uses about half a quart of oil in 200 hours. The coolant level has not budged in 400 hours.
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
