Using a Kubota to Power a Generator for Extended Periods
   / Using a Kubota to Power a Generator for Extended Periods #31
   / Using a Kubota to Power a Generator for Extended Periods #32
if the power unit were installed in a marine application, it may run continuously for several weeks. with lives depending on it.
   / Using a Kubota to Power a Generator for Extended Periods #33
If I had money, I wouldn't buy a Jag or Lamborgini . I would scour the planet for a nice original Lister. These poor quality clones are probably not worth the little they are asking. And a real crap shoot.
   / Using a Kubota to Power a Generator for Extended Periods #34
I thought you couldn't buy India Listers anymore due to the EPA banning the import of them???
   / Using a Kubota to Power a Generator for Extended Periods #35
So anyone get to use their Genny last night or today?
I was about to go hook mine to the well when duke got the electrons running back and forth again. ;)
   / Using a Kubota to Power a Generator for Extended Periods #36
The Listers are being brought in as "Compressors". In Canada, anyway.
Many feature cardboard shims.
   / Using a Kubota to Power a Generator for Extended Periods #37
   / Using a Kubota to Power a Generator for Extended Periods #38
I guess we are just fortunate here in Ea WA. The longest outage in the 34+ years I've been here was 28 hours. Hardly worth even the thought of standby power.
I do have a 3000 watt Honda but its used to power my tools when I'm out on the property. A friend worked on one of those big factory boats up in AK. They catch & process cod. Their diesel engines run 4+ months, non-stop, keeping the boat & refrigeration going. Once a commercial fishing boat leaves port - it will normally only shut down the diesel engine if there is a problem.
   / Using a Kubota to Power a Generator for Extended Periods #39
I just bought a yanmar ydg5500 portable and wired into the house with a gen inlet box. Probably took 3 hours to do. I bought it off of Craigslist for less than half brand new.
If i were to keep my tractor at my primary residence, i would have absolutely no problem running a pto genny for days. My B2920 uses about half a quart of oil in 200 hours. The coolant level has not budged in 400 hours.
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
1449 (A57192)
1449 (A57192)
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
