Buying Advice Used sub/compact tractor, what to buy?
   / Used sub/compact tractor, what to buy?
Do you have mechanical skills?
How wide of trench are you planning on?
I'm pretty mechanically inclined. I can DIY maintenance/repairs as necessary. I have thought about going with a bigger, older unit, but I'm concerned with ending up with a machine that needs major/costly repairs within a few years.
My plan for the foundation work was to go the full 6' at about 3-4' width and taper up/out from there. The dirt from the full depth area will all be moved elsewhere. The tapered area will be set aside and put back in place.
(This won't be my first time doing foundation work, but it would be my first time doing the excavating myself.)
   / Used sub/compact tractor, what to buy? #22
Ok, that changes everything
There's no way you'd get me digging that much of a trench with a SCUT or CUT backhoe.
Seriously, that's not in the "a bit here and there" category unless you're a vampire and have centuries to do "a bit here and there" unless "a bit" is like 20 hours a week.
   / Used sub/compact tractor, what to buy? #23
as someone currently digging a very long ditch, you will probably be very unhappy.
the biggest issue is getting rid of the dirt, you need a very low dump trailer for the small height you can get over the trailer. I am digging a 2 foot ditch and I have to back up
I designed this system to move the tractor while I am in backhoe mode, and if I didn't have it, I would rent or buy an excavator, and I am still looking at them.
The biggest problem is getting close to the house without falling in the hole, you will never get to 6.5 feet, simply due to clearance swing and over hang.
I wish you luck.
   / Used sub/compact tractor, what to buy? #24
I wonder if you'd be happier with a little mini excavator? The little gas units sold for $4-5,000 and the diesel units sold for $7-8,000 at the local equipment auction about a month ago.
   / Used sub/compact tractor, what to buy? #25
Seems to me with digging the taper at 3 foot wide, a bigger machine is not quite as big of a handicap, since you can be a bit off angle and then get closer to the foundation as you go. If nothing else I would suggest at least checking the local craigslist and maybe FB marketplace for a full sized machine.
I never see reasonably priced mini or midi ex's around here, but usually a few full size TLB's many times sub 10K for serviceable units. I was thinking how many times reading brand new CUT threads that the purchase turned into absolute nightmare on this site. Good used equipment can be exactly that many times because it is "used".
   / Used sub/compact tractor, what to buy? #27
I was curious after reading your post about sub $10k full size TLB units so I checked CL for my area and surrounding states. The used units are considerably more expensive than $10K. 3 to 6 times more expensive.
   / Used sub/compact tractor, what to buy? #28
The 2019 RK with all the extra equipment sounds like a pretty good deal, but it wont have the reach to do that foundation work you are talking about. Hire out the excavation, keep the tractor for other things that need done.
   / Used sub/compact tractor, what to buy? #29
If you use the TBN search feature, you can find any threads discussing the machines you are considering. Sometimes there is good information to be found that way. Members come and go and may not respond to your thread, but sometimes there's good information still to be found just by using the search feature.
   / Used sub/compact tractor, what to buy? #30
Depending on the lengths of your foundations and soils, it might be quicker to do them with the Front-End-Loader (FEL) than a backhoe. Depends on whether you have the room on the ends to do it as drive throughs. Or short enough that the backing would be short enough to not slow you down too much.
The backhoes on SCUTs and CUTs, are frequently lacking in breakout, depth and reach. And most have 4 to 5-foot FEL buckets. So, it may be more efficient to move dirt with the FEL.
If there is length for pull throughs, I might look at using a box blade for the bulk of the material.
RE parts for the RK. The bulk of the mechanical parts will cross to a TYM. Things like the gauge panel, and controls are different, but can be replaced with TYM parts which will just look different. And TYM doesn't change base parts with great frequency. My TYM T233 is a 2007, and the T293, is I think 2017. All of the major repair parts have the same part numbers for my two tractors, except the engine parts. And normal wear parts are the same as the current production T25. The difference is in the engines and coupling from the engine to the transmission. And on my T233 and T293, the engines are pretty common Mitsubishi engines. If I search for engine parts online by omitting the first five characters of the TYM part number, and include Mitsubishi in the search terms, the Mitsubishi parts show up.
2017 CATERPILLAR 304E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
