Used Orchard Tractor
/ Used Orchard Tractor #1
Van Wen
MA near NH
Kubota m7500dt, Same Frutteto 75, Ford 2600, MF 1020
Not real familiar with the JD model #'s. I'm looking for a used 4WD tractor, 80+/- HP, and low COG. My main constraint is lugging a 500 gal sprayer up hills. Any particular model #'s I should look at?
/ Used Orchard Tractor #2
New Holland has had the orchard tractor market covered for several years. TN90F, TN95F, TN95FA, and T4050F models with Auto 4WD and SuperSteer outperform the rest. Don't skimp on HP if you are using a 500 gal airblast sprayer on steep hills.
/ Used Orchard Tractor #3
Depending on your row spacing John Deere did have a 6000 series orchard model I don't recall the designation but it was a very low tractor. Around here most everyone uses New Holland TN-F's or John Deere 5000N which are low and narrow tractors. They work well in the vineyards and the orchards. They have hp up into the 80 pto range.
/ Used Orchard Tractor #4
We have a couple MF 4355 orchard Tractors. They have 85 pto hp. They are good little machines that can do a lot of work on a little fuel. I might be looking at letting one go here soon since I don't have as much work any more.
/ Used Orchard Tractor #5
If you are interested in learning more about these tractors and why we bought them, I wouldn't mind at all. The cab filtration system is the best out there and seals up really nice with a low low profile. My direct contract is j_z_hammer at hotmail dot com.
/ Used Orchard Tractor #6
Massey has never been a player around here for some reason. I know the local Massey dealer use to sell tons of 135's back before my time which is why so many are around here still. However, when the kids took over they have lost a lot of customers. I have been looking at vineyard/orchard tractors for quite a while now and I have never seen one Massey vineyard/orchard tractor at their dealership when I have stopped. They carry Landini and push those tractors more so then the Masseys in the narrow tractors for orchard/vineyards. The last time I talked to them they said they couldn't even get a Massey narrow tractor as Massey didn't have anything to offer at the time as they were in between models.
I would love to hear a review of your tractors though and if you could post up some pics that would be great.
Narrow wold be nice, but low profiles what I'd like We've got 20' row spacing (M7/ central leader) and relatively level or terraced on 75%. It's the 25% that could use something lower than our Kubota M7500DT. It's 80" wide and even with that I have a couple of quesy spots.
Evan
/ Used Orchard Tractor #8
Evan
The orchard/vineyard tractors are narrow "and" low. They are quite stable even with their narrow width but if you have the room for a larger, low profile tractor then go for it. I don't see very many of those type of tractors in this area but I know other areas have a ton of them. Location is a funny thing when it comes to what type of equipment people use for the same jobs:)
/ Used Orchard Tractor #9
I am interested in the tractors. Please provide more info.
/ Used Orchard Tractor #10
Did you find your used orchard tractor yet? If not, check out: autrusa.com/used.html -there is a used 87hp Carraro TTR-9400 listed with only 177 hrs for 35K. These tractors have an extremly low center of gravity and unique weight distribution that makes them great on slopes, as well as a reversible work station that lets you push or pull implements. If you are looking for a compact but powerful tractor with lots of versatility, these tractors can't be beat!
/ Used Orchard Tractor #11
If you have a dealer nearby, check out the Deutz-Fahr specialty tractors. They have a good variety of 80-100HP orchard models. I have a 97HP open station low profile that I am testing now. It is not narrow, just low. So far, I really like it.
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
2015 Ford F-550 4x4 Mason Dump Truck (A66736)
2015 Ford F-550...
2001 Generac SG0060 75kVA Natural Gas Generator (A66734)
2001 Generac...
2007 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2007 Kubota...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
