Used L5240
/ Used L5240 #1
gwood12345
Elkton, SD
none
I am looking at buying a 2008 L5240 with box blade and around 600 hours and was wondering if 19,000 is a good price and if will be a good tractor for lifting round bales and pulling a 2 bottom plow or a 6 foot tiller. I was also wondering which would be better for tilling 2-3 acres plow and disc or a tiller.
/ Used L5240 #2
not sure on the price. but the tractor will do all that you asked about. i have a 5240 cab with a tiller and it works wonders. not a single complaint about the tractor (well maybe one.....the a/c could be better)
/ Used L5240 #3
that price sounds pretty good to me.an i know itll do everything you need an want todo.
/ Used L5240 #4
I don't really know about the price, but the 5240 is a really nice tractor, I have a L5740 which is essentially the same tractor and unlike crk133, my AC works fine.
I guess I am a bit old fashioned, but I like a plow and disk, plus they can usually be found used and are a lot cheaper. I have a small tiller for our BX which gives a great finish; guess it depends on what you are expecting and how much you want to spend.
If he doesn't show up Buppies owns one, might PM him, he is always willing to help.
/ Used L5240 #5
This tractor should be very well suited for your use . I am very pleased with mine. The tiller will give you a very fine finish and the hp of this tractor is more than sufficient . As Triple R said my ac works well in 102 heat with 70 percent humidity. Great tractor and does all that I ask
/ Used L5240 #6
well my a/c issue has been fixed. dropped it off at my automechanic and apparently the belt was really lose. so after 4 years it works properly. it had been into my kubota dealer but they always sadi it worked fine. i am glad to have my issue resolved!
/ Used L5240 #7
Glad to hear it, we try to check our belts on a fairly regular basis and keep everything blown out as they can get clogged pretty quickly..
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
Takeuchi TL10V2...
