Used 7193
/ Used 7193 #1
roscioli
Massachusetts
Any idea how much a unit like this would go for? 108 Hours, 2 wheel drive, "About 20 hp diesel", loader with turf tires. I will attempt to attatch a pic. Thanks guys, I know, just another newbie looking for quick info. Sorry, I am a member on other (non-tractor) forums, and I know how annoying the newbie can be! When you let me know what you think its worth, I will let you know what the guy is asking, and what I decided. PS. I think 2 wheel drive will be OK for my application, and the turf tires are definately needed. Thanks!
/ Used 7193
Forgot to mention perhaps the most important thing.... Its Hydrostatic. thanks
/ Used 7193 #3
You might try going to the link below, it will give you a value.
www.machinerylink.com/resources/uevg/sbm/default.asp
I have a 7234, a little bigger than this one but a fine tractor. What you'll find is that the cleaner the tractor and the lower the hours they will ask what they want for price. You might want to see if there is a local Cub dealer when you need filters, etc. I'm in the North and the 4WD is mandatory for me plus the 4WD I think helps to make up for tractors much larger and heavier. If you have hilly terrain at all, once you fill the bucket up it takes the weight off the rear tires and you loose some traction so the front wheels on a 4WD help quite a bit.
Let us know how it turns out.
