Universal Quick Attach
/ Universal Quick Attach #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
When I get a larger PT, I would like to explore the option of adding a Skid Steer Universal Quick Attach system to the tractor. Advantages include the ability to choose from a much wider variety of attachments and manufactures, a ready market for used attachments to buy or sell, and the ability to rent attachments (although I’m not thrilled about mixing hydraulic fluids…I wonder if I could add a filter to the attachment return line?).
Anyone tried this? I have looked for a Quick Attach system that could be retrofitted to the PT and haven’t found one. Any ideas?
/ Universal Quick Attach #2
<font color="red"> (although I’m not thrilled about mixing hydraulic fluids…I wonder if I could add a filter to the attachment return line?). </font>
My experience has been that I have been unable to rent hydraulically powered attachments separately because of fluid incompatibilities. Rental firms in my area simply require the rental of a machine as well to get the hydraulic attachment.
/ Universal Quick Attach #3
I would drain the rental attachment as much as I could first. Most dont hold much fluid anyway. I sure agree to filter the fluid first, if you cant get rid of it. I also like a water filter on any fluid that is critical. I hate breakdowns!
/ Universal Quick Attach #4
Marrt:
There are posts for quick attach kits to go on other FELs, and a 1445 owner converted his, and should be able to tell you what's involved.
PT1445
Might be a good project for that older model 1845 that will be back on e-bay. Not far from you. /forums/images/graemlins/wink.gif
Take a look at the plate in this link. According to the text, this plate will:
- "Modernize older skid steers to utilize todays work saving equipment" and
- "Just one plate transforms older skid steers into multi-functional machines that adapt to any Quick Attach™ attachment".
However, it looks to me like this plate is for the attachments...not the skid steer itself. What am i missing?
/ Universal Quick Attach #6
Marrt:
I don't have any experience with skid steers. I can't tell from the website if that's an adapter or an implement plate. You may want to ping on Mark1445 to needle him about not yet posting the photos. If he doesn't chime in, you might send a PM to Gatorboy (Dave Hoffman). He bought a Bobcat not too long ago. Also, as I recall, Mark Chalkley has the universal quick attach on his Earth Force, so he also be able to describe the configuration, hydraulic hookups, etc.
/ Universal Quick Attach #7
Mart - I think Richard has a converter plate - maybe he will post a photo
/ Universal Quick Attach #8
<font color="red"> However, it looks to me like this plate is for the attachments... </font>
You are correct--this plate is for the attachment.
The link below is for the the tractor:
Try this link
I believe I have finally found an adaptor that will work. Take a look at “Cat. I or II 3-Point Hitch to Universal Skid-Steer Mount“ in this link (scroll down to bottom of page). I think this adaptor can be modified to covert a PT to use skid steer attachments.
/ Universal Quick Attach #10
<font color="red"> believe I have finally found an adaptor that will work. Take a look at “Cat. I or II 3-Point Hitch to Universal Skid-Steer Mount“ </font>
It appears to me that the locking wedges and the fabricated plate could be used, and then weld a PT plate on the back instead of the 3 pt hitch connections that are pictured.
But that would definitely be a custom job and might be quite heavy--particularly in light of the fact you still have to add the weight of the skid steer attachment.
/ Universal Quick Attach #11
if you need any help ... i am testing some prototype machine for one of the partners of that company and am going there tomorrow .... Wednesday ... to pick up the prototype which needed some adjustments. /forums/images/graemlins/grin.gif
/ Universal Quick Attach #12
Marrt
I have and use exactly what you have in mind. (as Ed indicated) I'll take some pictures and get them posted, but it won't be until I get to the office on Monday. I welded a pt reciever plat to an ATI "tach all" universal skid steer plate: http://www.preseeder.com/
Good luck
Richard
Richard, thanks. Pics would definitely be helpful. The adapter I noted above costs about $675 shipped to a business address. That's not too bad I guess. However, I do wonder if the additional attachment flexability will be worth the investment. My guess is "yes", but only if one intends to buy (collect) a number of attachments. That said, if one wants forks or a PHD, the recovery may be sooner as the PT forks and PHD are a little expensive (although most of their other attachments seem to be reasonable priced).
/ Universal Quick Attach #14
Marrt. Here is is the diagram I drew when I designed my Universal attachment plate. I had to run back and forth to my local Bobcat dealership a couple of times to get the measurments off other skidsteers just right.
I removed my Power-Track plate and took it to my local welder with my measurements. For 150 bucks he cut, beveled the top edge 45 deg, and welded 5/8" thick steel to it that makes a perfect fit for any attachment. I also had him add 1 inch in length to the Power-Trac quick attach pins so they would drop down further into misc. attachments.
The best thing about converting your Power-Trac plate is that you get to keep the quick attach design from Power-Track (very important to me). The only drawback is you have to cut new holes for the locking pins to drop down into in each of the new implements you buy. No problem if you have a plasma cutter or are good with a simple cutting torch. Also on a couple of attachments I have had to weld on extra metal plate for the locking pins to go into.
My next addition will be to move the locking pins out further to the sides where all attachments have the holes allready. It should be fairly simple to replace the existing quick attach ram with a longer ram and drill and tap new holes for the locking pins at the correct width.
I'll still try to get some pictures of all this soon, I have been soo busy I only have had time to read others postings and saw you were about to spend around $700. and give up your Quick Attach feature on your Power Trac. To me the speed at changing attachments is worth more than double that.
/ Universal Quick Attach #15
The adapter I use to attach 3-point implements to my EarthForce EF-500 is Kasco's Switch Hitch. (It's at the bottom of the page.) It's plenty heavy duty, fairly priced (I don't recall exactly what I paid for it), and also has a 2" receiver tube to allow a standard trailer hitch for moving trailers, etc.
/ Universal Quick Attach #16
Hello, Stranger; glad to see you back. Your link didn't work for me, so I edited it to take out the extra "http://".
/ Universal Quick Attach #17
Could it be /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif..long time Mark,hope all is well and you'll shall{update}share some pics of your "Beast Master"
37.2..Clear sky. /forums/images/graemlins/cool.gif
/ Universal Quick Attach #18
Well I'll be darned! Look who came home for the holidays! /forums/images/graemlins/laugh.gif
You gotta lotta catchin' up to do, fella. Feel free to regale us with whatcha been up to.
/ Universal Quick Attach #19
Welcome back Mark. /forums/images/graemlins/laugh.gif
/ Universal Quick Attach #20
Like what you did to your Quich-Attach plate. I have an older 1445 that I would like to adapt just like yours. Would you be willing to layout the measurements for the quick attach plate plus the addition to fit the skidsteer attachments. Thanks
J.J.
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2015 John Deere Z950M 72in Zero Turn Mower (A59228)
2015 John Deere...
2015 Ford Fusion Hybrid Sedan (A59231)
2015 Ford Fusion...
Deere 333G (A53317)
Deere 333G (A53317)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
