Understanding Curb Weight, GVWR, Towing and CDL requirements
   / Understanding Curb Weight, GVWR, Towing and CDL requirements #41
Any single vehicle with a gross vehicle weight rating (GVWR) of 26,001 pounds or more.
Any combination vehicle with a gross combination weight rating of 26,001 or more pounds, if the trailer(s) has a GVWR of 10,001 or more pounds
This is correct. People are missing the ”, if” part of the rule. If the trailer has a GVWR of 10,000 or less pounds and the tow vehicle has a GVWR of 26,000 or less pounds then you do not need a CDL. This combination would allow a maximum of 36,000 pounds to be driven without a CDL.
@Omega-Woods, I hope you don't mind me asking a question on your thread, but it might yield some advice that is beneficial to you, as well...
I have a Kubota that weighs in at 13,000 lbs. Based on what I've read in this thread, I won't be able to trailer it without a CDL, period. But I could haul it on the back of a truck without a CDL if I could find a truck with a GVW below 26,000 lbs AND the capacity to carry 13,000 lbs. on it.
Is there such an animal? Am I looking for something like a rollback? Thanks in advance!
I don't mind, of course.
I have heard that you now have to take one of the CDL courses and have a CDL learners permit in some states before you can take the test. Passing the knowledge test is a requirement for the learner's permit.
  • To be eligible to apply for a commercial driver license, federal rules state that you must:
    • Must be 21 years old to: Drive across state lines. OR operate a vehicle containing hazardous materials.
    • Have no prior disqualifying criminal offenses. Certain criminal felonies may disqualify you from CDL eligibility.
    • Complete an entry-level commercial driver training program (see below for more details on this CDL requirement).
This is true but you can take the knowledge test training online.
   / Understanding Curb Weight, GVWR, Towing and CDL requirements #43
Regardless of the weight you are hauling in the truck, or towing on the trailer;
If "ANY combination of vehicles which has a gross combination weight rating or gross combination weight of 11,794 kilograms or more (26,001 pounds or more) whichever is greater" you are in need of CDL
Wrong.
K5lqw has stated it correctly again.
I wonder how many other people are gonna chime in here with incorrect information???? Or a misunderstanding that the 26K limit has the condition of the trailer needing to be over 10k?
Do people even read the posts in the thread before commenting?
   / Understanding Curb Weight, GVWR, Towing and CDL requirements #44
You can tow a 9,999 trailer behind a 25,999 truck.
Another misconception is with air brakes, but lets not go there on this thread
   / Understanding Curb Weight, GVWR, Towing and CDL requirements #45
Wrong.
The problem is not the folks here not understanding it is the DOT officer not understanding. It is a poorly written rule. The word “Any” at the beginning of the sentence causes people to stop reading and miss the word “if”.
Wrong.
In their defense, it's very confusing. I've read the requirements many times and it only now is starting to make sense to me.
You can pull a 9k gvwr trailer with a 25k gvwr truck and not need a CDL (right?)
BUT if your trailer is 12k gvwr and your truck is 23k gvwr, then you do (right?)
But if your trailer is 14k gvwr and your truck is 11.5k gvwr, then you don't.
The flowchart is helpful.
   / Understanding Curb Weight, GVWR, Towing and CDL requirements #48
That's how I understand it.
This is my worry!
   / Understanding Curb Weight, GVWR, Towing and CDL requirements #50
This is my worry!
I would not worry at all. It can be cleared up in court. Plus, the chances of being stopped is small as long as you obey all the other traffic laws and do not wreck.
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2023 Kubota L6060HST Compact Utility Tractor (A56438)
2023 Kubota...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
Kivel Pallet Forks (A57149)
Kivel Pallet Forks...
Hook & Cable Strap (A59076)
Hook & Cable Strap...
