Underground Eave Downspout Drainage
/ Underground Eave Downspout Drainage #11
If I had that set up, I would run a line from that back corner of the house, to basically where you’re standing to take that picture. Picking up both downspouts, running to daylight.
Going under the concrete would be the biggest challenge, but not impossible.
/ Underground Eave Downspout Drainage #12
I've saw a diverter valve mounted just above ground level where the downspout goes into the tile. Flip the handle to divert the water above ground. Flip the handle to dump into the drain tile.
I was looking for a more passive solution for if something happens with the drain pipe (i.e. freezing, clogging, overwhelmed).
Looking over the grade again, unless I'm getting into a very big ditching project, it doesn't look like I have enough slope to drain to daylight, so I may be stick drainage on top of the grade, or a drywell (which I don't have much faith in).
/ Underground Eave Downspout Drainage #14
Design an air gap in the vertical downspout. It would allow water to escape if the tile plugged.
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
207274 (A52708)
207274 (A52708)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2006 Lufkin FLII 45ft. 40 Ton T/A Piggyback Flatbed Trailer (A59230)
2006 Lufkin FLII...
