Underground Air Line
/ Underground Air Line #21
You can tell CurlyDave has been around the block a few times. He is a practical thinker with lots of common sense. Great alternative suggestion Dave.
CurlyDave I think you win!! I'll run the power line thru the pipe and get a cheap compressor. I'm still going to run a drag line within the pipe as members recommended in case I want to pull something thru later.
Thanks all!!!!!!
/ Underground Air Line #24
Dougryan said:
Someone told me that you can tie thread (sewing thread) to a tissue and suck it through with a shop-vac, then use the thread to pull a heaver string through.
Doug
That will work. I had about 100 feet of underground conduit that I needed to pull electrical service entrance cable through. Tied contractor cord to a chunk of fiberglas insulation. Shop vac pulled it through fine.
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
2011 Ford F-150 Pickup Truck (A66736)
2011 Ford F-150...
2019 Toyota Camry Sedan (A66738)
2019 Toyota Camry...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
