Uh, Oh! 4x10 Flash Codes!!
/ Uh, Oh! 4x10 Flash Codes!! #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Just ran in to check the owners manual, Got a short long long short error. What's that? (No it's not in the owner's manual) It did say it was safe to drive. It said most reset with a "reboot", guess I'll try that!
I looked all over the machine when I bought it. There are NO "Powered by Windows XP" stickers anywhere on it...
/ Uh, Oh! 4x10 Flash Codes!! #2
Re: Uh, Oh! 4x10 Dlash Codes!!
Don't do this until you've talked to your dealer...but I reckon to "reboot" your tractor, you'll have to disconnect the battery. Probably leave it disconnected for a minute or so...
Let us know what yr dealer says to do, please.
Thanks, actually it is just a restart. and I found where Jason from K.C.Canary addressed this:
<font color="green">
Short, long, long, short or .--. is indeed the fault code for the mfwd sensor . If you have cruise control it will not function. The flywheel speed sensor is also the same part # as the mfwd sensor. So in my opinion the flywheel speed sensor could possibly fail, Their is an internal wiring problem inside certain speed sensors. Deere has corrected the problem with a fix as fail . This doesnt mean that everybody with e-hydros has to worry, not everybody will experience this. contact your dealer. The kit consist of both the mfwd and flywheel sensors and take about 5 minutes to install.
</font>
I'll retry it and if a reboot doesn't do it, then call the dealer. I didn't mention it, but the Cruise control wasn't working, either.
/ Uh, Oh! 4x10 Flash Codes!! #4
Check out THIS LINK to a previous thread on the same fault code.
Hope this helps.
EDIT: Dang, I posted the same time your second post did.
Thanks!! So far a reboot fixed it... /forums/images/graemlins/grin.gif
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
L6060 Kubota For Sale
Generac Generator (A61572)
Generac Generator...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
