udt vs super udt
/ udt vs super udt #21
Until I see a VOA and UOA, the new Super SUT is a ripoff. The SUDT for years was overpriced and pimped as it was the best. Now the new fluid is almost the same in price (but way better per dealers)...something smells wrong.
/ udt vs super udt #22
  • MSDS%20SUDT-2.pdf
/ udt vs super udt #24
Here is a document I got several years ago when I bought my old L3710, Kubota's explanation of the difference between UDT and Super UDT.
  • Super UDT Specs general.pdf
/ udt vs super udt #25
Good information, thanks for sharing. Philip.
/ udt vs super udt #26
Jay, with that lag, how much additional wear to you feel you might be getting out of the hydraulic system??????
I did state in my earlier post of the differences between super and super 2 and for us here in NY the UDT to Super which is superior in the cold over UDT
Extra wear? Probably none. Definitely none on the hydraulic system - hydraulic systems don't actually 'wear', do they? I'd guess that any additional clutch wear is negligible. I don't know exactly why the lag exists, since I don't understand how the hydraulic clutch works, but I'd guess that it is a small orifice valve pushing the clutch plates together after a shuttle/gear change, and the cold fluid takes a bit to get moving. The clutch engagement itself isn't all that different, and the operation goes to normal pretty fast once things warm up. There is always a bit of a lag, unless the machine/hydraulics is/are roaring hot.
JayC
/ udt vs super udt #27
Thanks and you are right. THis was done years ago. I remember this back in 2003. Again the hyd fluid has been a money maker for Kubota for years. Even there oil spec is nothing "strange".
For me, use Amsoil hyd and you know what you are getting.
/ udt vs super udt #28
I bought 2018 MX tractor. The manual calls for SUDT2 for 'enhanced' ownership. Whatever that means. With a footnote that regular UDT is also permitted in the machine too.
I wonder which fluid was put in it from the factory, as I broke a fitting and want to add a gallon or so. My guess would be the regular (less expensive) UDT.
/ udt vs super udt #29
just did the 400 hr change on the l2500 and when i ask for super udt I was told they do not carry it- said it was mostly used up north in the cold temps-what is the diff between the super and std udt--------curious
Well, I live in the south. Worked at Kubota. They do sell it down here.
/ udt vs super udt #30
UDT = 20w hydraulic oil
SUDT = 10w20 hydraulic oil
SUDT2 = ? I've heard it's still 10w20 and is a synthetic blend but I haven't seen it in writing as of yet. The bottle does say that it has "synthetic performance" but it doesn't come right out and say it's synthetic or a blend.
SUDT2 is replacing SUDT so you can expect to see less and less of the SUDT.
(my local dealer carries UDT & SUDT2)
As been pointed out, SUDT (and perhaps SUDT2) has better numbers/ratings in high heat and low cold conditions which would presumably indicate it's a better all around hydraulic oil but, people have been using UDT for decades without issue or performance loss.
So it's basically six of this and a 1/2 dozen of the other :D
The above doesn't include an info on Canadian Kubota fluids or other manufacturers' hydraulic oils :D
clear as mud? :D
Dave
SUDT doesn't cavitate and foam like UDT. Burn a couple of skid steers down and you'll figure it out.
/ udt vs super udt #31
So Kubota's 'enhanced ownership' is when the HST does not burn up/down whatever :oops:
Guess I want enhanced ownership then🙃
Can I ask what happened to the orange tractor forum? Every link I find is a dead end?
/ udt vs super udt #32
No it means if it is supposed to use SUDT to perform properly and you use regular fluid and then gripe cause it ain't doin right. I don't care what you use.
/ udt vs super udt #33
What I posted was what I read in the manual. Use SUDT-2 for an enhanced ownership experience. Whatever enhanced ownership is and then this = Regular UDT is also permitted for use in this machine.
/ udt vs super udt #34
My wife's Honda was one of the last to print 5w-30 oil on the engine oil cap. The next year, they are stamped with, what would soon become popular, 5w-20.
There's no way that they changed the engine mid stream. It's just that the 5w-20 oil came of age, maybe, maybe provided a 1/100 more mpg? Who knows or cares. I'm with TripleR. Oil debates are absurd.
Unless you go wacko, and very far afield, oil is oil. It's wet. It does it's job. Just as folks use 5w-30 in their cars without any noticeable difference, this shouldn't be a debate about one versus the other. Is there a difference? Yes. But......Will the world stop spinning one way or the other? Nope.
I live too dang far north not to use both SUDT in my tractor and 5w-20 in my wife's engine for -10 start ups.
Yes, our Tacoma's oil cap clearly says 5w30 on it. It's now running with 0w20 like the other 2 gasoline engines.
/ udt vs super udt #35
IMHO, yes and no. You’ll notice a heavier oil makes starting harder on a cold morning. You’ll notice thin 0W oil disappearing on the dipstick between oil changes that you won’t get if with a 5w or 10w. Of course the manufacturers will say that’s normal. You’ll also notice how much a 0W splashes everywhere when you change the oil.
/ udt vs super udt #36
Did anyone notice this thread is 10 years old?
Going with a thinner oil that protects well should not be a problem.
But in 10 years hopefully engines and oils have gotten better.
/ udt vs super udt #37
There were some really good posters back 10 years ago........Sure do miss them now.
/ udt vs super udt #38
curious, you did not mention your location. wouldn't that be, given the consensus, the answer to your question?
so "up north" means you're southern?
/ udt vs super udt #40
I have been using the forum at the above link.
