udt vs super udt
   / udt vs super udt #21
Until I see a VOA and UOA, the new Super SUT is a ripoff. The SUDT for years was overpriced and pimped as it was the best. Now the new fluid is almost the same in price (but way better per dealers)...something smells wrong.
   / udt vs super udt #22
  • MSDS%20SUDT-2.pdf
   / udt vs super udt #24
Here is a document I got several years ago when I bought my old L3710, Kubota's explanation of the difference between UDT and Super UDT.
  • Super UDT Specs general.pdf
   / udt vs super udt #25
Good information, thanks for sharing. Philip.
   / udt vs super udt #26
Jay, with that lag, how much additional wear to you feel you might be getting out of the hydraulic system??????
I did state in my earlier post of the differences between super and super 2 and for us here in NY the UDT to Super which is superior in the cold over UDT
Extra wear? Probably none. Definitely none on the hydraulic system - hydraulic systems don't actually 'wear', do they? I'd guess that any additional clutch wear is negligible. I don't know exactly why the lag exists, since I don't understand how the hydraulic clutch works, but I'd guess that it is a small orifice valve pushing the clutch plates together after a shuttle/gear change, and the cold fluid takes a bit to get moving. The clutch engagement itself isn't all that different, and the operation goes to normal pretty fast once things warm up. There is always a bit of a lag, unless the machine/hydraulics is/are roaring hot.
JayC
   / udt vs super udt #27
Thanks and you are right. THis was done years ago. I remember this back in 2003. Again the hyd fluid has been a money maker for Kubota for years. Even there oil spec is nothing "strange".
For me, use Amsoil hyd and you know what you are getting.
   / udt vs super udt #28
I bought 2018 MX tractor. The manual calls for SUDT2 for 'enhanced' ownership. Whatever that means. With a footnote that regular UDT is also permitted in the machine too.
I wonder which fluid was put in it from the factory, as I broke a fitting and want to add a gallon or so. My guess would be the regular (less expensive) UDT.
   / udt vs super udt #29
just did the 400 hr change on the l2500 and when i ask for super udt I was told they do not carry it- said it was mostly used up north in the cold temps-what is the diff between the super and std udt--------curious
Well, I live in the south. Worked at Kubota. They do sell it down here.
   / udt vs super udt #30
UDT = 20w hydraulic oil
SUDT = 10w20 hydraulic oil
SUDT2 = ? I've heard it's still 10w20 and is a synthetic blend but I haven't seen it in writing as of yet. The bottle does say that it has "synthetic performance" but it doesn't come right out and say it's synthetic or a blend.
SUDT2 is replacing SUDT so you can expect to see less and less of the SUDT.
(my local dealer carries UDT & SUDT2)
As been pointed out, SUDT (and perhaps SUDT2) has better numbers/ratings in high heat and low cold conditions which would presumably indicate it's a better all around hydraulic oil but, people have been using UDT for decades without issue or performance loss.
So it's basically six of this and a 1/2 dozen of the other :D
The above doesn't include an info on Canadian Kubota fluids or other manufacturers' hydraulic oils :D
clear as mud? :D
Dave
SUDT doesn't cavitate and foam like UDT. Burn a couple of skid steers down and you'll figure it out.
2015 COACHMEN CATALINA CAMPER (A55745)
2015 COACHMEN...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
(6) New 2x15 E-Track Ratchet Straps (A54865)
(6) New 2x15...
Mobile toilet (A53424)
