udt vs super udt
/ udt vs super udt #1
jimbo64
just did the 400 hr change on the l2500 and when i ask for super udt I was told they do not carry it- said it was mostly used up north in the cold temps-what is the diff between the super and std udt--------curious
/ udt vs super udt #3
The "super" products are more expensive to produce, likely, given their higher retail prices.
They have more refined or superior additives one supposes. For sure, a quick comparison shows higher flash points (good in hot weather) and better cold weather flow.
Not unlike a straight 20w oil versus a 5w-20 oil. Both work, but I'll bet you pay more for the 5w-20 multi viscosity oil.
In spite of the bias of certain southern dealerships, and despite the silly packaging Kubota did with the SUDT by putting snow flakes on the bottle reinforcing this silliness, the SUDT is merely a low viscosity, multi-viscosity fluid. John Deere and many, many others offer various grades of tractor fluid.
But, if you're a dealer in the south, why bother with having to stock it and fuss with it. Would your customers pay more, as they must for the "super"? Doubtful. Or at least, not enough of them.
Now, back to our regular programing, as they say.
/ udt vs super udt #4
Super UDT is better for the cold the UDT as it it is a little thinner and is better with wet clutches. Super 2 takes it farther yet on both of the above as well as more protection from corrosion caused from condensation.
When tractors are used for snow removal at short bursts (not running all day) they can have more moisture problems. Kubota designs there tractors to be able to work all day and with the changes in their market to less use they have found additives to overcome the problems do to the lack of running them long enough to count on evaportaion.
/ udt vs super udt #5
I live up in the north (Central Alberta) and I can't find sudt or sudt2 anywhere and all the dealers around here haven't even heard of it :(
/ udt vs super udt #6
Dealers don't carry it down here, but you can order it. I have used both and found no difference in performance or noise and have also used other brands.
Others will disagree vehemently; oil threads seem to get heated at times.
/ udt vs super udt #7
That is because Kubota contracts with a totally different oil company in Canada. I understand that there is ONLY a super type product available in Canada. Again, that makes life simpler. Who has excess shelf and storage space?
Again, this is a simple matter of storage and shelf space. Most folks in business would love not to have to stock and sell a bunch of different stuff with minutia of differences between them.
/ udt vs super udt #8
My wife's Honda was one of the last to print 5w-30 oil on the engine oil cap. The next year, they are stamped with, what would soon become popular, 5w-20.
There's no way that they changed the engine mid stream. It's just that the 5w-20 oil came of age, maybe, maybe provided a 1/100 more mpg? Who knows or cares. I'm with TripleR. Oil debates are absurd.
Unless you go wacko, and very far afield, oil is oil. It's wet. It does it's job. Just as folks use 5w-30 in their cars without any noticeable difference, this shouldn't be a debate about one versus the other. Is there a difference? Yes. But......Will the world stop spinning one way or the other? Nope.
I live too dang far north not to use both SUDT in my tractor and 5w-20 in my wife's engine for -10 start ups.
/ udt vs super udt #9
In my part of Canada we get what is called Premium UDT,just to add to the confusion.Not sure how it compares with the others but that is all my dealer said is available here.
/ udt vs super udt #10
My dealer and everyone else I talked to only sells and heard of regular udt (or "Premium UDT" as it's labeled) not even the super. Is there a product number for sudt2 that I could go to my dealer and order cause they are really good at that.
Half the time they don't know things exist until I hear about it on these forums and walk in there asking for it. They say no such item exists and I give them a part number and they are amazed that it does exist.
When they get requests now that they haven't heard of they call me to search and see if it exists and has a part number, lol.
/ udt vs super udt #11
I have used UDT and SUDT in my tractor, there is no difference that I can detect.
I was told SUDT is multiweight 10W-30 and UDT is straight 30. SUDT would be better in a cold climate.
/ udt vs super udt #12
Yes, Canada only sells "Premium" udt. No doubt equivalent to SUDT. Again, in the US, Kubota has been using Ashland (Valvoline) where in Canada, who did they contract with? Petro Canada?
/ udt vs super udt #13
UDT = 20w hydraulic oil
SUDT = 10w20 hydraulic oil
SUDT2 = ? I've heard it's still 10w20 and is a synthetic blend but I haven't seen it in writing as of yet. The bottle does say that it has "synthetic performance" but it doesn't come right out and say it's synthetic or a blend.
SUDT2 is replacing SUDT so you can expect to see less and less of the SUDT.
(my local dealer carries UDT & SUDT2)
As been pointed out, SUDT (and perhaps SUDT2) has better numbers/ratings in high heat and low cold conditions which would presumably indicate it's a better all around hydraulic oil but, people have been using UDT for decades without issue or performance loss.
So it's basically six of this and a 1/2 dozen of the other :D
The above doesn't include an info on Canadian Kubota fluids or other manufacturers' hydraulic oils :D
clear as mud? :D
Dave
/ udt vs super udt #14
That's a good question, I will have to see if it says who they contract with on the jug.
/ udt vs super udt #17
I've heard that the newer little hydro tractors (like the BXs) are sensitive to that sort of thing. Old klunkers like my L4200GST don't care much. I went from what I think was Super UDT (when I bought it), to a UDT/SUDT mix, to a 100% generic UDT-equiv. from Sams ($7/gal). Everything works exactly the same, as far as I can tell. I do get a slight shifting lag when it is below freezing, but the additional lag goes away after a few minutes.
JayC
/ udt vs super udt #18
Jay, with that lag, how much additional wear to you feel you might be getting out of the hydraulic system??????
I did state in my earlier post of the differences between super and super 2 and for us here in NY the UDT to Super which is superior in the cold over UDT
/ udt vs super udt #19
JayC
Actually we are on our second BX and have used everything in them including UDT, SUDT, Sinclair, Ambra and Case and we couldn't tell any difference in any of them and we use our machines pretty hard.
40' Shipping Container (A66285)
40' Shipping...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2015 Deere 210G (A64126)
2015 Deere 210G...
