U Joint angle limit
/ U Joint angle limit #1
Don_Sullivan
Southern NH
Kubota BX1500
I've had my BX1500 for about two months now and am very pleased with most everything. The MMM deck has just been put into hibernation and the snowblower is standing by for the first serious blast.
One loose end. The manual for the Quick Hitch Mid PTO kit, BX2712, has a warning not to raise or lower the snowblower while blowing snow. I asked one of the service techs at the dealer about this and he said the universal joints in the Quick Hitch drive line are not happy operating at angles over about 15 degrees. With a crude level protractor I found that at 15 degrees the SB shave plate is a little over 8 inches off the ground, compared with its maximum lift of about 10 inches (20 degrees).
Experience with my old (Cub Cadet) SB has demonstrated the value of maximum lift in coping with deep snow with frequent switches up and down. I guess I could cope with a 15 degree limit but does anyone out there have any info on such low angle limits for Ujoints? My only other info is a limit of 40 degrees on my Howard HR3 tiller.
This forum has been most helpful in my Kubota education. Thanks to all contributors.
Don Sullivan
/ U Joint angle limit #3
"I guess I could cope with a 15 degree limit but does anyone out there have any info on such low angle limits for Ujoints?"
I can't say anything more then you have on PTO shafts, but automotive U-joints (for the drive shaft) have been held to a 15° limit as well. It is my understanding that angles > 15° will result in excessive wear on the U-Joints.
Limited usage on your snow blower might not be much of a problem...but then again you may have to replace your PTO shaft (or rebuild it) sooner then later.
/ U Joint angle limit #4
Shaft and joint life start dropping off quickly after about 1 or 2 degree. by 15 degrees it is in the order of 1/25 of the life at 1 degree, at 45 deg it is like 1/1000 or something like that!
In practical sense, the life drops off when the angle is 0 due to lube getting driven out since the needles aren't rolling anymore.
So you would have to balance the increase in life due to reduce load vs decrease in life due to operating angle. Have fun!
Thanks for the info. I wonder why the Howard HR3 tiller manual talks about a maximum angle of 40 degrees. Translation from Spanish?
As a practical matter most of the snowblowing is done near or at ground level anyway so if it's just a case of increased wear, rather than self-destruction, I should relax and enjoy it.
/ U Joint angle limit #6
Don:
If you look at the angle of the ujoint coming out of the middle pto drive and the angle of the ujoint where the shaft goes into the front quick mount I think you might get an idea of the angle that is used in the fixed drive train. Not too sure of the angle right now as I have't put the blower back on my 2200.
Last winter I ran the blower at full speed when moving snow and did not shut it off when I raied it to go after the heavy stuff by the street. In fact I would start on the snow piles with the blower fully raised and at full speed. After chewing up a foot of so I would back up, drop the blower to ground level and go after it again. I have a few stumps that I have to avoid by running the blower raised.
The ujoints seemed very tight after the season. No wobble or anything.
The important thing here is to keep the joints greased, the chain lubed with a good chain saw bar lube, and the front shafts lubed as well. The ujoints are no problem if you keep their angle pretty flat when greasing them. Don't forget that there is a zerk on the female end of the drive shaft coming
from the PTO.
You'll enjoy the blower, it will move anything and everything that gets in its way. Watch out for rocks!
sandyc;
I don't even want to think about last winter - the snow was over the tops of the pasture posts. But I coped using the scheme you described and would like to do the same with the BX1500 when necessary. All lube locations found, checked and fixed where necessary.
Based on slowzuki's comment yestarday I asked Google about "universal joint angle life" and, as usual, got more than I ever want to know about the subject. Found references to a wide range of operating angles and can see that the mid-PTO's max speed of 2500 prm (if I can believe the manual) would be harder on ujoints than the rear-PTO's 540 rpm used by my tiller.
I took the BX outside yesterday and ran the SB (in low position, parked) at various speeds and thought it sounded pretty noisy. Will try to find a similar unit to listen to to make sure I don't have a problem.
Don
/ U Joint angle limit #8
I'll just 2nd Roy's post, a complete and correct answer.
/ U Joint angle limit #9
Yes, sorry not to mention speed, I was looking at car driveshaft universals. Obviously lower speed ones such as in a 4wd front truck axle can handle more angularity before extreme wear becomes an issue!
/ U Joint angle limit #10
Don:
My blower makes a bit of noise but when you figure that there are four ujoints, an auger and a blower as well as a gear box and a large chain ...well there is a lot of metal rockin and rollin on the front of the tractor. Once you get used to the noise it will sound normal especially when you see the snow being thrown fifty feet from where you are. Make sure you don't bury your wife's roses or you might have to redig the holes when you replace the roses in the spring.....take it from one who has been there. Watch the kids around the machine as well. The stones and ice thrown out of the shoot really travel.
/ U Joint angle limit #11
As the angle increases, it becomes increasingly harder on the driving and driven pieces of equipment, too.
Believe it or not, output rpm is not constant when the angle between the two shafts is other than zero. Throughout one full turn of rotation, the output shaft lags, then leads, the input shaft in rotational speed. Whatever is attached to this shaft experiences this same, very rapid, change of speed. If the driven piece of equipment has a lot of intertia, (like a pull-behind rotary cutter, in a turn) it can really work the pto drive train in the tractor.
/ U Joint angle limit #12
</font><font color="blue" class="small">( ...output rpm is not constant when the angle between the two shafts is other than zero. )</font>
This is true at the ujoints but to clarify, I think if the tractor pto and the implement input shaft are parallel then only the low-inertia driveshaft varies speed through a revolution. This is because the same angles at opposite ends of the driveshaft cancel each other. Only an implement that is tilted relative to the tractor would vary in speed. I think it is necessary to orient the ujoint yokes in the same axis to accomplish this.
/ U Joint angle limit #13
I agree with California’s answer. The keyed slip joint on your BX1500 MMM drive shaft takes care of aligning its u-joints properly. If oriented improperly I think you would experience some serious vibration.
2009 Ford Ranger Pickup Truck (A66736)
2009 Ford Ranger...
2013 WACKER NEUSON HF 690 FLAMELESS HEATER (INOPERABLE) (A68842)
2013 WACKER NEUSON...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
