TYM Dash pinout
/ TYM Dash pinout #1
ziegler
Royalton, ny
Scat Trak 1300HD; MF 65 gas; TYM T474
I have a T474 but assuming the dash display is the same on all cab models. The dash has a parking brake light but mine is not hooked up to the parking brake switch. I see several wires missing from the plug. Does anyone have the pin out of the plug? Or know of a source for replacement pins? Unfortunately, they are not weatherpack plugs.
/ TYM Dash pinout #2
I took this from a T474 workshop manual. Not sure it helps. Can you tell if this matches yours? This service manual is kinda bad to be honest.
I did the same on my Branson as you want to do. In my case, it was to make the 4x4 and Neutral light to work. I add to instal the proximity switches for both Shuttle and 4x4 levers.
The plug, I'm pretty sure it's just a Molex plug. I didn't bother with finding the pins. Just exposed a good amount of cooper on the wire, shove it in the plug with a little bit of hot glue and tied the wires to main dash harness with electrical tape and zip ties. It's been holding very well since.
/ TYM Dash pinout #3
My 674 has idiot lights that I'm not sure work. Also, I have no temp gauge. The dealer confirmed there is no temp gauge. My point is, you may not have some of the things you would expect.
/ TYM Dash pinout
Where did you get your T474 workshop manual from? I have been looking for one. I even contacted TYM several times with no luck.
It looks like the dash works on 5v(21). You had no issues feeding it 12v?
/ TYM Dash pinout #5
I can't remember. Probably on one of the TYM Facebook groups.
If you want, I'll upload mine to Google Drive and send you the link.
/ TYM Dash pinout
Looks like I do have a wire in pin #8. So I e-mailed my dealer to see what my options are.
Thanks.
/ TYM Dash pinout
Yes, please.
/ TYM Dash pinout #8
Thanks.
Wouldn't surprised me if they had all the wires ready to go and just didn't hooked up to the switch or maybe is just the switch missing.
Maybe check the parking brake linkage for some wires nearby or something.
Yes, please.
Ok I'll send it once I get home and have a bit of free time.
/ TYM Dash pinout #9
PM sent.
/ TYM Dash pinout
Would of been nice if TYM had a better resolution on pages 211 & 212. But both show the brake switch going to another 3-wire box, 1-in & 2-out, one to the dash & one to the rear lights.
/ TYM Dash pinout #12
The TYM World site has the manuals for their recent tractors. For older tractors they don’t list, such as my T233, one of the dealers, (Smith’s Engerprises), archived all of the manuals on the old TYM site, and you can down load them from their archive. Just Google search “TYM t233 service manual pdf”. And the Smith’s Enterprise archive will turn up.
2020 MACK DUMPTRUCK (A67714)
2020 MACK...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
