Tym 474 engine regen
/ Tym 474 engine regen #1
Bt298
Tym 474HST
At 107 hrs got the regen warning with the 3 beeps etc. Have a kukje engine, followed the instructions 2700 rpms, 76 degree coolant temp. Everything in neutral. Press and hold the regen button, but it will not regen, am i doing something wrong. I reset the light Can I do a forced regen. Any help would be great. Thanks
/ Tym 474 engine regen #2
I had trouble with mine and the tech put it into regen. If I remember correctly, he turned the machine off. Turned it back on, made sure the brake was on, throttled it all the way up and held the regen button in for a long time - 45 seconds or something. Make sure everything is off (PTO...) and the E-Brake is on.
/ Tym 474 engine regen #3
If you posted the same question in the FB TYM group, I will answer the same? Did you try to reinitialize the DPF controller?
2021 CATERPILLAR 316FL EXCAVATOR (A65056)
2021 CATERPILLAR...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
CAT D250E Transmission (A68134)
CAT D250E...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
PANTHER T14R TRACKED DUMPER (A65056)
PANTHER T14R...
