Buying Advice TX1300 Advice needed
/ TX1300 Advice needed #1
Huntinguy
Demokratik Republik of Washington
Iseke TX1300
I have a TX1300 that I have not started for a few years (work got in the way of life.)
What is the best way to restart it without damaging it? I have thought about pulling the glow plugs and spraying some WD-40 down the cylinders but, I don't know what the torque is for them.
Where can I find a list of the fluids for it? Probably should change them all.
Also, there is a valve under the seat and I have no clue what it does.
/ TX1300 Advice needed #2
hi new here just bought a Ts1610f i also have the valve under the seat no idea what its for. does anyone know where i can get a workshop manual for the TS1610f
/ TX1300 Advice needed #3
I Dont ever Remember seeing the Valve before in the Pic on the Smaller One I traded off, Not saying it wasn,t there , But sure Never had to mess with it .
As Far as Manuals contact A Member here Below He should be able to Get You a Manual of a Similar US model , There not Cheap but What is These days, :D . As Far as The Fluids Hopefully Someone with A Similar Model will Come along soon with Info . Best of Luck, Bob
Leonard Sheaffer
sheaftractor@grics.net
Sheaffer's Town & Country Tractor
/ TX1300 Advice needed #4
i tried there and could'nt find anything for iseki what is the american equilavent
/ TX1300 Advice needed #5
I also have an Iseki TS1610F. Here is a photo of the underseat area. No valve like that one exists there as you can see. What valve are you talking about?
/ TX1300 Advice needed #7
Should be a manual override for the electric solonoid to operate an auxilluary implement.
/ TX1300 Advice needed #8
/ TX1300 Advice needed #9
63DH8 is correct, it is the lowering speed adjustment for your 3 point hitch.
The TX1300 is the G152 (2 wheel drive model)
The TX1300F is the G154 (4 wheel drive model)
The TX1300 has a slightly smaller CC displacement (40.82cc) than the TX1500 (G172) and TX1500F (G174) 2 cyl diesel (46.62cc)
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
John Deere 8320R (A64126)
John Deere 8320R...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
