Two vs three wire breakaway switches
/ Two vs three wire breakaway switches #1
Dougeye
Bronze Member
North Saanich,BC
Mahindra eMax 20s, Takeuchi TB210R
One to the battery, one to the trailer brake wire, and in the case of a three wire switch, one to ground. Why the difference? Are two wire switches grounded through the mounting plate?
/ Two vs three wire breakaway switches #2
A switch doesn't have to ground, hence one wire from the charge battery and one to the brakes on a two wire. On most trailers I have worked on this is what it has, pretty simple and durable.
I don't know why grounding the switch would make a difference but it could be another ground in the system so if you are running a two wire cable to the axle and have to cut it to splice into the supply wire to the brakes you could splice the ground of the brake cable together AND ground it again at the switch. (But I could be wrong on this too and there may be another purpose for the third wire.)
/ Two vs three wire breakaway switches #3
I found the diagram. But it depends on the switch. Most have 1 wire to battery, 1 to brakes, 1 wire is a ground.
I always just install the two wire brake away controller. It's a much easier and cleaner install. Just connect 1 wire to battery. And splice the other wire into the brake wire coming from the plug going to the electric brakes.
Here's a screen shot from the Etrailer page.View attachment 661947
Solved. The switch itself isn't grounded, the ground wire is on switches that have an LED that comes on when the switch is activated. The two wire switches don't have the LED.
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
CAT D5 Rear Screen (A68134)
CAT D5 Rear Screen...
2012 Cadillac CTS Sedan (A66738)
2012 Cadillac CTS...
2020 KOMATSU PC360LC-11 EXCAVATOR (A65056)
2020 KOMATSU...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
MASSEY FERGUSON 5465 TRACTOR (A65057)
MASSEY FERGUSON...
