TWIDDLING MY THUMB
/ TWIDDLING MY THUMB
Here i welded up the thumb arm assembly
another
Heres the thumb arm pin holder.It will be the first thing welded on the tractor
Dry run on the bench,ok shes ready
Got the tractor in the garage.Made a mark with the bucket curled up completely so i wouldnt get it too far forward
After un hooking my battery,iI clamped it on,and welded it.If you recall i was gonna clamp it on,then i got lazy /forums/images/graemlins/grin.gif
ok,thats welded on,now i put on the thumb arms,and connected it to the rear pin holder,in its storage hole.This is so id know where to place it
I installed the brace,hooked up the battary,heres a garage test
open
try again
arms locked at 90 degrees,closed up.The arms are longer than the bucket,so they wont go in,like a previous poster told me not to do
folded up
I was unsuccessful with folding up the support arm too.I made it strong instead of foldable /forums/images/graemlins/grin.gifI will replace that with a piston soon though Well all i got now is to drill the bolts to accept a hitch pin.The pivet bolt is gonna have a dbl nut.Then a little paint ,primer.Ill show you a pic tommorow. A rock lifting test -pics going into the kubota section now.WHEW /forums/images/graemlins/shocked.gifTHE POSTING WAS HARDER THAN THE THUMBBUILDING /forums/images/graemlins/grin.gif
ALAN
/ TWIDDLING MY THUMB #54
REALLY really nice job !!!! Fist class all the way !!!! My hat's off to you, CHEERS!!!!!!
/ TWIDDLING MY THUMB #55
Very nice job, I look forward to your next project.
/ TWIDDLING MY THUMB #57
I can't believe I delayed so long to build my thumb. I finished it the other day, and it works great! I looked at many other thumb implementations and plans before I designed mine. I was worried that a mechanical thumb would be disappointing since I have used hydraulic thumbs on excavators before (sweeeeet). I used a std CAT 1 toplink for adjustability and upgradability to hydraulic. It is plenty strong for this application as it experiences way less stress than a toplink used with a scraper box. I wrapped the fwd bracket around the dipper stick since I was concerned that the pull stresses here would distort the 3/16 dipper steel. My photo shows lifting a 400# log.
/ TWIDDLING MY THUMB #58
Another photo. I used replaceable teeth because I pick up a lot of rocks. The 2 teeth mesh with the middle tooth on my 12-inch bucket. I saw no need for serrations on the thumb and that proved out. I am able to grasp very large rocks and logs quite securely. I can remove the thumb in a few seconds by pulling 2 pins.
/ TWIDDLING MY THUMB #60
Man! Too cool using a top link!! I think I've got to make one now since I've got a couple of those laying around! Thanks fo rthe pics. BobG in VA
6x6 Hunting Box Blind (A65579)
6x6 Hunting Box...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
30x57 Welding Table (A65640)
30x57 Welding...
