Turntable With Track System
/ Turntable With Track System #1
Big Barn
Super Member
Victoria, B C
More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
I got this turntable from a sandblast outfit today. Should make a good portable fixture table for welding and yet to be determined tasks.
The table is 1/4” steel 30” diameter with 1/4” holes for securing fixtures. Sealed bearings on the table axle as well as the four rollers. It weighs 90 pounds and has a 750 pound rated capacity. I also have 3 sections of track for it.
The turntable itself is only five inches high and will sit flat on a welding table or any flat surface as well as on the tracks.
I will most likely make a dedicated stand for it with provision to clip on track extensions. This would allow me to use the turntable at any height with the aid of a forklift or my high lift pallet jack. Or it could be placed on the welding table with or without track. Lots of possibilities!
/ Turntable With Track System #2
Does it have a provision to attach your ground lead to the base of the rotating table? Or do you have to attach it to the piece itself?
Aaron Z
/ Turntable With Track System #3
Awesome turntable!
BTW, What kind of table surface is it sitting on? Looks like it might be polished stone, maybe granite?
No provision, Aaron. It was designed to be a turntable for sandblasting and as such doesn’t have the rotating ground source a proper welding rotator would have.
Awesome turntable!
3 inch steel top, 3Ts.
/ Turntable With Track System #6
Very cool... a luxury welding or blasting accessory for sure! I like it. Curious as to the benefits of the linear track though?
Mark it was most likely for loading heavy items with a forklift onto the table and then sliding it deeper into the cabinet to blast.
/ Turntable With Track System #8
Mark it was most likely for loading heavy items with a forklift into the table and then sliding it deeper into the cabinet to blast.
Ah yes... loading into a cabinet. Of course.
/ Turntable With Track System #9
Always wanted one of those. Nice..
Here’s the bench I built to use the turntable for small weld/fabrication projects.
The rectangular work surface can be offset or removed to allow more linear travel for the turntable.
/ Turntable With Track System #11
What's next a robot to grab and manipulate your work? :thumbsup:
I chopped the end off some sliding arm clamps and welded on 1/2 inch bolts to match the holes on my table.
/ Turntable With Track System #13
Terry, since you cut off the part of those Stronghand clamps where the V jaws go, you might wanna get a set or two of these (if you do much with pipe/tube)
MagHold & MagRest V-Pad Kits - Strong Hand Tools
Altho they left out the CENTER magnet on the base; don't remember if it's easy to MOVE one of the magnets to the center so it'd work better on the swivel/screw end... Steve
Good idea, Steve. I think I have a couple. I’ll try it tomorrow.
/ Turntable With Track System #15
Between Bukit and Barn, I am backlogged with ideas... I need to retire.
BuckitCase’s idea to use the V pad works well
/ Turntable With Track System #17
Terry, my intention was using the SEPARATE, magnets included, version of the V pads; but I like your implementation BETTER - I have a couple of the "built-in magnets" version, but since I have 2 DOZEN of the "4 in 1" clamps (12 of the 8", 12 of the 12" and a couple of the "one hand") and they all come with the "step over" and V pads, (not positive the "one hand" clamps have those extras) I'm not envisioning a shortage of the "regular", non-magnet pads :laughing:
I also had bought a bunch of the little round neodymium magnets, and your implementation puts the magnet right in the center where it SHOULD be.
'Nuther possibly useful hint - if you have more than a couple of those "4 in 1" clamps, there may be times (I've had a couple) where you need a TALLER "step-over" clamp - neat thing is, ALL those extra pieces are 3/8" thread. Just take 2 or 3 of the screw-in spacers and STACK 'em. (screwed together, of course :D )... Steve
More good suggestions. Thanks Steve.
My “better” implementation of built in magnet version was a matter of “run what ya brung” and not the result of any serious thinking.
And btw I purchased new Bessey clamps on sale locally
but I decided to surgically alter my older used Stronghands. (Which are 1/4 inch longer in comparable sizes and of equal quality. Uncertain of metal hardness though if that is even a concern in clamps this small. )
Works as advertised. So far so good....
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
King Kutter II Tiller for sale.
King Kutter II...
2002 FORD F-250 SUPER DUTY LARIAT SERVICE TRUCK (A64276)
2002 FORD F-250...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2022 EZ-GO ELITE...
