Turning up the hydraulics
   / Turning up the hydraulics #11
the pressure relief valve is shimed at the end of the spring, the addition of another shim at the same thickness of the shim that is used will adjust the pressure up that amount of the thickness { 0.0050in shim should bring the pressure up increased 50psi } from the wsm manual, you need a pressure gauge, hook up and check the pressure now then shim and recheck pressure,Caution is used with any hydraulic unit.
   / Turning up the hydraulics #12
2007 GMC 2500HD (A56436)
2007 GMC 2500HD...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
