turning radius with ground engaging attachments
/ turning radius with ground engaging attachments #1
texastomtom
Texas
JD 4720 2004 / MF230
I'd like to know what is 'generally acceptably in terms of turning with ground engaging equipment 'engaged'
eg... truning with disc down to work around trees etc..
any thoughts on other equupment ,,, blades and such dont really seem to be an issue turning with equipment in engaged.
TexasTomTom /forums/images/graemlins/confused.gif
/ turning radius with ground engaging attachments #2
I managed to twist a box blade scarfier when it got tangled up on a tight turn. Now I pick it up when turning.
/ turning radius with ground engaging attachments #3
Ground engaging implements are designed to run in a straight line. Or I should say your tractor's 3ph is designed to run these in a straight line. Any time you try to turn with one down, it is going to put a sideways stress on your 3ph. If the ground is really soft, you might get away with gentle sweeping turns, but I would not overdo it.
Thanks
I'll keep it gentle if I do any turning with equipment engaged
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2019 Kawasaki Mule 4010 EPS (A62613)
2019 Kawasaki Mule...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
