turning radius with ground engaging attachments
/ turning radius with ground engaging attachments #1
texastomtom
Texas
JD 4720 2004 / MF230
I'd like to know what is 'generally acceptably in terms of turning with ground engaging equipment 'engaged'
eg... truning with disc down to work around trees etc..
any thoughts on other equupment ,,, blades and such dont really seem to be an issue turning with equipment in engaged.
TexasTomTom /forums/images/graemlins/confused.gif
/ turning radius with ground engaging attachments #2
I managed to twist a box blade scarfier when it got tangled up on a tight turn. Now I pick it up when turning.
/ turning radius with ground engaging attachments #3
Ground engaging implements are designed to run in a straight line. Or I should say your tractor's 3ph is designed to run these in a straight line. Any time you try to turn with one down, it is going to put a sideways stress on your 3ph. If the ground is really soft, you might get away with gentle sweeping turns, but I would not overdo it.
Thanks
I'll keep it gentle if I do any turning with equipment engaged
2013 FORD F-150 (A65643)
2013 FORD F-150...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Lincoln Electric Invertee V-300 Pro Welder & Lincoln Electric LN-7 (A65579)
Lincoln Electric...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2022 YANMAR VIO35-6A EXCAVATOR (A63276)
2022 YANMAR...
