turnbuckles
/ turnbuckles #1
AlabamaFarmer
Minooka, Alabama
MF 1533 4WD
I have a 1533 with a landspride brush cutter, boxblade, ....all the stuff you guys have talked me into buying. (at least that's what I tell my wife!). I can't get the top bar or turnbuckle on the leveling arm (?) to stay where I put them. I crank down the nuts. It is worse on the brush cutter. It gets to be a pain using something and thinking it is lifting all the way up to turn around and find out it is only a foot off the ground.
/ turnbuckles #2
Wrap a black rubber bungee cord around it a couple of turns & hook the other end to the lift arm or something secure. or Weld a weight to one end of the adjusting handle. or weld a washer to each end of the handle & secure it with a bungee to something solid.
/ turnbuckles #3
I know what you mean about the dumb nut... I have taken a wrench to tighten it, I hold the "T" with a another wrench and give it all I have... Has stayed.
What I wonder if we can (I have the same MF as you) use the adjustment link from the Power Shuttle/Hydro trans tractors... It has a crank handle for that adjustment. IF you have your Operator book look at the lower picture on page 55 to see what I am talking about.
OPPS you are talking about the top link, not the right lift link, sorry. I don't have a problem at all with the top link.
/ turnbuckles
I have trouble with both of them. I'll start tightening down the nut on the top bar more and see how that works.
/ turnbuckles #5
Normally just a tap on the third arm nut is enough to keep it in place. Most of the time, I even forget to do that and it has never moved. /forums/images/graemlins/grin.gif I don't know why they put those stupid European side links on. Get the dealer to order you a crank side link.
/ turnbuckles #6
I had this problem with my 1433V since the day I bought it! I tried everything until I finally *** enough to my dealer and he replaced it with a crank adjustable link; that problem is solved!
The top link is just as bad. I took it off and had the turnbuckle ends and nuts faced off to give a smoother contact surface; no luck. I used a honking adjustable on the nut and a length of tubing on the cross piece; still wouldn't hold and managed to bend the cross piece. I finally adapted a wrench that my buddy made to grab both sides of the cross piece and tighten the nut with a wrench. (I'll try to post a photo of the wrench next week) This works but is a real pain to loosen when you want to.
The Ford top links have a flat threaded plate that acts as the nut. My friend gives it a slight tap to tighten, a slightly harder tap to loosen and it never moves when in use. I was going to go to a hydraulic top link some day so I've held off on just buying a Ford top link, but I've been thinking about it for years so maybe I should just do it...?
/ turnbuckles #7
Maybe an answer to the loose nut problem would be to weld a weight or hook to the nut to make it heavy on one side letting gravity want to hold it from loosening or put a bungee on the hook and tie it off somewhere... Spray a little rust on it , It'll never move then /forums/images/graemlins/grin.gif
/ turnbuckles #8
</font><font color="blue" class="small">( I had this problem with my 1433V since the day I bought it! I tried everything until I finally <font color="red"> complained </font> enough to my dealer and he replaced it with a crank adjustable link; that problem is solved!
)</font>
I couldn't edit; time had expired.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
(6) 250 Gal Chemical Totes (A64127)
(6) 250 Gal...
2019 KENWORTH T370 FLATBED TRUCK (A65643)
2019 KENWORTH T370...
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
