Turn PTO by hand
/ Turn PTO by hand #1
bacononeactual
Michigan
JD 770; LS G3038H
On my gear tractor I can turn my PTO shaft by hand (with engine off ) to line up spline with implement shaft. Can't do that on my g3038h, even with tractor in neutral. Is this typical on hydro tractors?
/ Turn PTO by hand #2
I suspect the difference is that your LS PTO is electrically actuated where your gear tractor has clutch actuated PTO.
Sent from my iPad using TractorByNet
/ Turn PTO by hand #3
My gear LS does the same thing.
Eugene
/ Turn PTO by hand #4
It's what is called indexing, or getting a greasy hand. A very handy thing to be able to do. Some PTOs even have a brake in which case I suspect you would not be able to turn it.
/ Turn PTO by hand
Correct, it is electrically actuated. I guess the answer is that there is no way to make the PTO shaft turn in this case. It's just a pain to have to turn the implement drive on some implements to match.
/ Turn PTO by hand #6
A pain to be sure. My mower is so old there is enough slack in the gears and shaft that I could "probably" make it work- no on second thought it is so old it uses a shear pin at the PTO instead of the new kind with the spring lock. The back hoe, yes you can turn it by hand. The tiller- no way as it is new and there is no play at all. What does the owner's manual say?
/ Turn PTO by hand #7
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
LULL 1044C-54 SERIES II Telehandler (A65579)
LULL 1044C-54...
