turbocharging a Kubota B7100
   / turbocharging a Kubota B7100 #22
   / turbocharging a Kubota B7100 #23
Nice job!
But please install a real air filter to preserve your hard work!
Those air filters flow a lot of air but are very poor at filtering dust particles.
You probably know that but were anxious to show it off.
Again nice job!
90cummins
   / turbocharging a Kubota B7100 #26
I installed a turbo on my 1720 Ford because I wanted more power but not a new bigger tractor.
Best mod ever, no issues with lots of power when needed.
Used a turbo off s Saab Garrett GT1752 if my memory serves me correct.
Not a expensive mod for me but time consuming planning and implementing.
There are photos in the review section.
90cummins
Can you provide a link? Could not find it in the reviews section.
Thx
   / turbocharging a Kubota B7100 #28
With only 13 pto HP stock . Even a full on turbo and inter cooler update would be good for 6-7HP more . As project without consideration or cost or time . Sure go ahead .
Better to go and purchase a 40+ HP tractor instead .
   / turbocharging a Kubota B7100 #29
Sounds like a fun high school auto mechanics project, one I would sure learn from.
But if your tractor is worth, say, ten grand or more, pretty much kiss market value
good bye unless you are willing to put it all back together as original to sell it.
If it's a less expensive tractor and asset value is not an issue, and you don't wreck your engine by trial and error,
I'd say go at it. Most guys who fool with this stuff want to blow lots of black smoke it seems vs trying to pull another
five feet of disc.
I know my Kubota has a turbo but not sure of the other two, but likely. I should look them up on tractordata.com
Lot of engines get more power just by flowing more fuel. But perhaps that only works well with boosted engines and surely engines that flow adequate air to
make it all happen. Too small piping and you might as well put a clarinet on the end of your turbo... ;)
   / turbocharging a Kubota B7100 #30
I put a turbo on a tiny Yanmar 1110d tractor. Used a turbo off a Yamaha Seca motorcycle. The turbo was small enough to fit on your open hand. It was a fun projrct and only cost a few hundred dollars.
Could you give some details as to the power of the Yanmar before and after the Turbo install?
   / turbocharging a Kubota B7100 #32
Good thread. Good information given here by a few experienced owners. Flanked by many naysayers. Some of which don't even know if their tractor has a turbo or not. :D
   / turbocharging a Kubota B7100 #33
I'll stick with my comments and my happiness with admitting what I don't know. Some know everything.
:D
   / turbocharging a Kubota B7100 #34
:D
I hear ya. You gotta watch Fred!!!!! ;)
   / turbocharging a Kubota B7100 #35
If we assume the turbo provided a 40% power increase (big assumption here!) It would have brought it up to 15hp. I'll be honest, it felt stronger than that, but maybe it was the diesel. Was a bunch of fun mowing and blowing snow because it would keep on pulling.
Surprisingly, fueling wasn't an issue. I would have swore the pump would have needed a boost reference but even under boost it would still blow smoke.
200704 (A60430)
200704 (A60430)
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
