TSC Carry All, BX2200
/ TSC Carry All, BX2200 #1
Anonymous Poster
Epic Contributor
Has anyone attached a TSC Carry ALL to their BX2200. I would like to have a platform for the back that would allow me to haul things such as firewood and a 55 gallon drum of water.
A second use would be to transport a chipper/shreader that weighs about 150 pounds. It has wheels but the wheels are very narrow and it tips on my hillsides when I try to tow it.
If you have one, what size did you make the platform?
How has it worked for you?
John
/ TSC Carry All, BX2200 #2
the 55 gallon drum will be getting close to the max weight capaicty on the BX three point hitch. Simple solution, don't fill it up all the way.
If you do a search on Carry all there are many posts here regarding platform size etc.
I'd like to get one myself someday. Too bad the nearest TSC is in NY. I know i can get them elsewhere, but not for the same amount of $$$$
JWE: On my 3pt i've made the reciever type hitch like some of the guys here have and use the plug in trailer hitch platform mine happens to be aluminium but there are many different types, some are steel and some have medium high sides and also at least one that hinges up.
Follow the hitch/3pt weight limitations and each style platform also has a weight limit. I don't put anything to heavey on mine EX: gas powered waterpump,generator or propane tank. On the rear it doesn't seem to bounce around as much as bouncing in the bucket. Could have made one but we had this one for camping already, propane tank and cooler fit perfect. Another .02
Cheers
Tony
I will be careful of the weight I put on the back. I plan to fill the drum about 2/3 s full (about 300 lbs).
I am mainly interested in knowing whether the TSC Carry All fits well on the BX2200.
I will do a search for platform sizes.
Thanks
John
Looked at the TSC website if its the black carry all that your refering to then it is simmilar to the aluminium one I have its dimmensions are 22"x60" our tractors are less than 48" wide so you would have an over hange of 6" per side. The steel one is more ridged than my aluminium one. If the mesh feels soft I put a piece of wood down to span the mesh. My wife can easily move the aluminium one around she didn't like the heft of the steel
Cheers
Tony
/ TSC Carry All, BX2200 #6
The carry-all from TSC will fit any cat 1 3ph. I have seen some new KK equipment coming out made just for sub-compacts. Don't know if a carry-all was part of them though.
/ TSC Carry All, BX2200 #7
I've been using one for the past year, it fits the BX2200 fine, and I have even adapted it to fit on the FEL to use as forks.as was posted by another member a while back.
see photo
JimC... Thanks for the information. How did you attach it to the bucket?
John
/ TSC Carry All, BX2200 #9
I welded a plate that goes under the lip of the FEL and the carry all sets on top of the front edge of the FEL,
see photo
/ TSC Carry All, BX2200 #10
Then I use a chain and a small boomer to hold the bottom of the carry all to the FEL
see photo
/ TSC Carry All, BX2200 #11
And the top of the carry all attaches to the trailer hitch socket I attached to the back of the FEL
I discribed the trailer hitch in a previous port under atachments a few months ago.
see photo
/ TSC Carry All, BX2200 #12
A better view of where the chain to hold the bottom of the carry all attaches
JimC
/ TSC Carry All, BX2200 #13
There are two plates added to the carry all that fit above and below the FEL lip.
JimC
JimC... Thanks for all of those photos. I can see exactly how you attached the carry all.
John
I have the carry-all from TSC for use with my BX-22. Price was right and it' works well. My platform is about 40" wide.
jbecker... thanks, I plan to make mine about the same size with removable sides about 18 inches high.
John
/ TSC Carry All, BX2200 #17
I have the TSC carry-all on my BX2200. I've just been using a pallet on mine as a platform (the one my tiller came on). Works for what I use it for, mostly hauling bags of "stuff" around, like compost, etc. I've had as many as 16 bags on it at once, with nominal weight 40lbs/bag, 640 lbs. Also had 9 bags in the FEL for counterweight. I've been thinking about putting a back on it to make it easier to stack the bags to the front.
Kevin
I'm planning on the removable sides, too. I just need the time (yea, right...<G>) and a trip to TSC to get some stake pockets. Maybe by next spring...
I will put 4 sides on mine. I better be careful with the type and thickness of material I choose. If I'm not careful the weight of the carry all will exceed the lift capacity of my BX2200! I may use treated 2X8s for the floor and treated 4 quarter for the sides (1 inch). Not sure how I will attach the stake pockets. I also want to make a dolly that I can set it on when I am not using it (2X4s and 4 casters).
John
/ TSC Carry All, BX2200 #20
I just toss a pallet on mine. I have a piece of plywood I can lay over the pallet if I need a "no hole" service to lay somthing on.
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2012 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2012 Ford F-150...
1828 (A61574)
1828 (A61574)
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
