Truss for pole building question..
/ Truss for pole building question.. #41
attached is the type gable I was talking about
as far as the bacing book goes they mosty covery bracing for houses not pole barns but all the Temp. barcing is the same. They truss plant "should" suppy the book but I would tell them you want one if they charge for it I would not think it is much bucause they don't want you to sue if something happens
/ Truss for pole building question.. #42
Lazy,
Let me see if I can explain the problem with putting the bracing between the trusses. Think of all those little 2’ (4’ or whatever) braces as having a hinge point at each end and think of the trusses a dominos.
Now lets say your on top of one of these dominos and it is a little out of plumb and a hinge is holding it from going over.
Now if that board goes over a bunch of the dominos with no hinges in that board the whole stack goes done. That is the reason for the x-bracing also.
I know what you’re thinking ……But I used a hanger so I am ok……nope you were lucky….A hanger is made to take the load vertical not to keep the board in it from rotating. Nail a hanger to a beam put you a short board in it hold the other end with only your hand and pull up or down and see how easy that hinge works.
I have never seen you barn but you might think about adding a few rat runs along the bottom side of the top chord of the trusses and x-bracing the gables.
Do you guys up there (I am in Fl so now snow) seen many pole barns that fall because of snow and think well the snow brought it down? Think again most likely it was lack of bracing. A building is a system and the trusses are just one part of that system….
Now with all that said I will add this. I have seen many buildings that are 100+ years old with no bracing and way too small of rafters…go firgue
/ Truss for pole building question.. #43
Chucko,
I've been a little confused with some of the terminology in this thread.
I've always understood "purlins" to be bracing placed within the wall structure horizonally between the studs, and tonailed to the studs. Sometimes referred to as fireblock, this was a standard in building construction before the advent of plywood sheathing. Purlins would also be placed between the rafters perhaps.
Horizonal pieces nailed or otherwise fastened to the side of the wall studs or rafters I have always understood to be called "lathing". These members are for the purpose of attaching plaster, metal sheathing, etc.
Maybe it's just a regional thing.
/ Truss for pole building question.. #44
yea that is a big problem in const.....too many terms for the samething
purlins, rat runs, lathing are all the same (to me anyway)
the thing you need to understand about "fire blocks" and toe nails is they have no structural value
fire blocks are to slow a fire in the wall and or to catch the edge of the plywood only....or to make me say bad words when I have to pull a wire later /forums/images/graemlins/smile.gif
/ Truss for pole building question.. #46
>or may say to wait until after the roof is installed and the truss is fully loaded before attaching it.
Up north that would mean waiting for a couple feet of snow before securing the trusses.
Also, the metal roof doesn't weigh much compared to the trusses themselves. Keep in mind that the gable end trusses are only supportting half the load of the interior trusses, so they aren't all going to be loaded evenly anyways.
/ Truss for pole building question.. #47
As far as going straight to the manufacturer of the trusses and having them build them, in my experience it will still be cheaper to go through the lumbar yard, in your case Lowes, since they get discounts from the truss builder. Your trusses will also be more of a "priority" as far as a time frame for the truss builder if they are building them for Lowes. A few years ago I had a rush job on some roof trusses. The truss plant told me 5 weeks, (busy time of year), went through a major lumbar yard and had them in 3 weeks.
As far as the trusses on the end as almost everyone has said these will need to be structural trusses since they will only be supported on the ends, which will probably end up looking like all the other trusses on the building unless they put some extra "scabs" in it for attaching you metal on 2' horizontal centers.
Did not mean to confuse anybody about the truss for the 16' door. This has nothing to do with the roof trusses. It looks like a floor truss that is specifically designed to span the long distance of a 16' overhead door and be beefy enough to support the garage spring, brackets and automatic garage door opening equipment at far less weight than an lvl and a lot less expensive.
You are headed in the right direction and have it figured out. Now just the fun part of putting it all together and enjoying the finished job.
Duane
/ Truss for pole building question.. #48
Hi
here is the website of the folks that put up my building. They have built just about every building in this area and I have never heard of any falling down. I'm sure the building are well designed and meet all the building codes.
http://www.bblconst.com/buildings.htm
Charlie.
Ok, so thats cleared up, but 2 questions, ok, if i add on some 'scabs' to the gable end trusses to attach the sheet metal lathing to, will it weaken the truss or anything? also, when i install the 16 foot garage door, is it ok to hold up the tracks and springs for the door by the truss like in a normal garage?
/ Truss for pole building question.. #50
</font><font color="blue" class="small">( is it ok to hold up the tracks and springs for the door by the truss like in a normal garage? )</font>
Good question. I'll be following that answer closely as I'll be install 3, 9X8s in mine. What is everybody's opinion of a ceiling as well? I'm considering 7/16" OSB as a ceiling or maybe drywall depending on pricing and my mood at the time of purchase.
/ Truss for pole building question.. #51
1 and 2 ...that should be no problem.....well unless you have say a solid steel door....but a normal door is fine
Just use you head and you will be fine
/ Truss for pole building question.. #52
dude if you are going with dry wall you will want your trueeses at 2' oc or the rat runs at 2' oc or it will sag..
be sure if you are going to put in a ceiling that the truss builder knows it...when you tell them "pole barn" they think open with no ceiling so the trusses will be designed with very little bottom load
/ Truss for pole building question.. #53
I had the truss guys engineer an open center truss. This gave me 12x45 ft open area with plenty of room to walk around side to side. Load bearing enough for almost anything I would want to store there. Also, the floor is 3/4" "screwed and glued" to the bottom member. I also did the outside storage roof this way and gained 9x20 ft. This also stiffen the building and added to the Hurricane strenghtening!
/ Truss for pole building question.. #54
Here is the smaller area.
/ Truss for pole building question.. #55
Chucko is absolutely right!
If you are going to install a ceiling you have to let the truss designer know. OSB and Drywall are heavy. Anything over 2' on sheet rock will sag!
If all your trusses are tied together well as per plans that come with your trusses a standard garage door bracket for the back of the rails for the garage will hang fine.
Duane.
/ Truss for pole building question.. #56
Jim,
I would go for the drywall myself, if for nothing more than a little more fire resistance and a lighter color (besides easier to slap some white paint on if you want lighter, it helps with reflecting light).
Your trusses are 24"OC, so you may be OK.
Jerry
i wont be putting in a ceiling, only hanging the garage door stuff, wich is a big 16 footer..wonder how much more the open center trusses are than the regular ones? I like the way yours is, thats cool!
/ Truss for pole building question.. #58
The cost difference will never outweigh the convenience of the additional storage space. You are only building this once, so you better make it the way you want it in the first place. A building is like a marriage..... if you mess up it costs you a lot before you get it straightened out....... build it right / marry the right person.... you will have a smile on your face for life.... /forums/images/graemlins/smile.gif Junkman the Philosopher.... /forums/images/graemlins/smile.gif /forums/images/graemlins/frown.gif
/ Truss for pole building question.. #59
I'm a retire builder / engineer . Just order a common truss and fill in for the siding nailing support with 2x 4's before you set them in place . We always sided are end trusses on the ground first . Much faster and safer .Since you do not have a end bearing wall the "Gable Style" truss would sag or fail . Once you fill in 1/2 of the truss the others will be the same lenght ,so you will need 4 of each lenght to do both trusses. It does not take that long and you can put the siding nailing strips on 16" or 24" (centers) depending on want you want and are using for a finished siding .
/ Truss for pole building question.. #60
Trusses are 2' on center as I'm doing OSB/shingled roof. Unfortunately my trusses are already in place, so it is a little tough to tell the builder that I want to do a ceiling some day. Mine is 30x48 with trusses 2' on center. They are made out of all 2x4 material. Ceiling is down the road a piece. Need to get the rest of the roof up and some walls up before even think about that, I was just curious.
