True operating weight
/ True operating weight #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
Can anyone shed a little light on wheather Kubotas listed weights are dry weight or with all the fluids.
For example, my 7500hst is listed at 1367lbs. With me, it goes to almost 1700lbs (not counting any implements). How much weight do all the fluids add to a typical tractor?
/ True operating weight #2
Kubota weights are without wheels and tires and minus fluids I think. J
/ True operating weight #3
A gallon of diesel is around 5.2 lbs, a gallon of oil is about 6lbs, and hydro fluid is about 6lbs per gallon. so the answer to the question - <font color=blue>How much weight do all the fluids add to a typical tractor?</font color=blue> is - Not much.
/ True operating weight #4
Are you sure about the 5.5 lbs for diesel? I thought it was more like 8.8 lbs.
Don
/ True operating weight #5
water is 8.33 pounds/gallon and oils float on water so I would asume that they weigh less. hydro/tranny fluid is about 7.2 a gallon.
/ True operating weight #6
My mistake. I picked that number up in another thread. :(
Don
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2022 EZ-GO ELITE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
