Truck or trailer problem
/ Truck or trailer problem #11
Being as both tow vehicles have a 7 pin connector, I would just get a 7 pin plug for your trailer as Diamondpilot suggested.
Unlike the 6 pin connector, they both should be wired the same.
Aaron Z
/ Truck or trailer problem #12
The trailer probably worked fine behind the Chevy because the fuse wasn't installed for the battery recharge. I've hooked up to a couple of stock trailers with the 6-pin wires and had to use the 7 to 6 pin adapter. Depends upon how the stock trailer is wired which 7 to 6 adapter I need to use. Funny though that any of the GM vehicles I've every towed with ('97 K1500, '99 Silverado, '00 Silverado, '05 Silverado, '06 Silverado, '02 Trailblazer, '05 Trailblazer, '08 Suburban) all of the 7 pins were wired fine when plugged into a properly wire 7-pin trailer. So what years were the GMs wired wrong?
/ Truck or trailer problem #13
Per Diamondpilot, the GMs that were wired wrong had factory 6 pin connectors. If it has a 7 pin on the truck, it should be fine. If the trailer has a 6 pin, it may be "standard" or it may use the GM/Chevy pattern.
Aaron Z
/ Truck or trailer problem #14
/ Truck or trailer problem #15
good point on the maxi fuse. if the tow package isn't installed and no maxi fuse.. there will be no power to the 'brake' pin on the 6 pin plug using a non switched over 6 to 7 adapter.
soundguy
/ Truck or trailer problem #17
you know how I feel about those 2 letters.. don't get me started!! :)
soundguy
4021 (A59228)
4021 (A59228)
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
1604 (A57192)
1604 (A57192)
(INOP) POLARIS RANGER 300 EFI RTV (A59823)
(INOP) POLARIS...
