Trouble with Home LED lights
/ Trouble with Home LED lights #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I have two out of 19 that seem to be getting dimmer with time. In the last couple of months it seems that these two have dropped to about half of less in lumen output. They are 5 years old and calculate to have possibly as much as 31,000 hours on them as they are on at 5 am or so and not off till 10 pm or later.
Anyone else noticed their LED lights putting out less lumens after a few years of use?
/ Trouble with Home LED lights #2
No, but I don't have as many hours as you do on any of mine. I wonder if some of the power supply components have "cooked" and changed value. what brand are these units?. Mine are all Cree.
I bought them at Lowes but I don't recall the brand name nor the LED manufacturer. 5 years ago, LED lights were just getting popular.
/ Trouble with Home LED lights #4
So far, I am very pleased by the Cree brand, we shall see how well they hold up long term.
/ Trouble with Home LED lights #5
As I understand it, the LED lights and fluorescents all use phosphor to convert energy (either blue light or plasma, respectively) into white light...and that phosphor gets used up over time and the bulb gets dimmer. The manufacturers of LED bulbs call them "dead" when they have lost enough light that you notice the difference, and I think 30k hours is right in line with how long many of them are rated to last. I'd say you've gotten what you're going to get out of them and call it good...
/ Trouble with Home LED lights #6
I just replaced two last night. One said cree the other one did not. The cree one was very dim and the other kept blinking on and off . These were only about a year old. All lights have LED bulbs but the dont last like they say.
/ Trouble with Home LED lights #7
How long is a piece of string? When talking about how long an LED lamp will last, that certainly seems to be the state of the question.
Manufacturers of LED lamps, which many regard as the next generation of lighting, destined to eventually replace today’s incandescent and compact fluorescent lighting sources, make wild claims as to product life.
Typical incandescent bulbs last 1,000 to 2,000 hours. But in speaking about LED replacements, lamp life is routinely quoted as 25,000 to 50,000 hours. Long lamp life, and the reduced power used to create the same amount of light, is what makes this technology so promising.
But what does a 25,000-hour life mean? As it turns out, no one is quite sure yet. The definitions surrounding LED lamps, a nascent technology, are still being made up as we go along.
One thing we do know: It means something different than when people think about the life of a regular light bulb.
When it’s said that a standard light bulb will last 1,000 hours, that is the mean time to failure: half the bulbs will fail by that point. And because lamp manufacturing has become so routine, most of the rest will fail within 100 hours or so of that point.
But LED lamps don’t “burn out.” Rather, like old generals, they just fade away.
When a manufacturer says that an LED lamp will last 25,000 or 50,000 hours, what the company actually means is that at that point, the light emanating from that product will be at 70 percent the level it was when new.
Why 70 percent? Turns out, it’s fairly arbitrary. Lighting industry engineers believe that at that point, most people can sense that the brightness isn’t what it was when the product was new. So they decided to make that the standard.
Of course, brightness is subject to the old frog in the boiling water syndrome. I’m sure that most people won’t even notice the lower level then, if they’ve lived with the same bulb for its entire life. (How many owners of rear projection DLP TVs only realize that a TV’s image has dimmed once they replace the bulb?)
If nothing else in the lamp fails, like its electronics, the product will continue to work until it becomes really dim. But some engineers are proposing a way to get around even that.
Their idea is that once the LEDs start to emit less light, increase the power to each one to increase its brightness. Unfortunately, that will also diminish the life of the lamp.
Good idea, or bad? “The utilities really don’t like this idea,” Fred Welsh, a Department of Energy consultant, told me on Thursday at a lighting conference sponsored by his federal agency.
Not only would contractors need to use thicker cables, but the utilities would need to create more power, partially negating the appeal of LED lighting in the first place.
But still, it’s in its early days, and no one yet knows how this will be settled, or how the consumer will be educated to think about “bulb life” in a different way than they have for the past 130 years. If consumers are going to switch to this new lighting technology, it’s an issue that needs to be settled.
And if it isn’t? “This is a potential black eye for the industry,” Mr. Welsh said.
/ Trouble with Home LED lights #8
So far all the LED lights I've installed have worked well. Failures do happen.
/ Trouble with Home LED lights #9
If Gary got 31000 hours and they are starting to get dim, I would say they did pretty good. That is 31 times longer than a standard bulb, and 15 times longer than a double life bulb. Not bad.
/ Trouble with Home LED lights #10
I put LED bulbs in my kitchen recessed fixtures because they are used alot at night. Unfortunately they emit enough RF that it messes up my AM radio. Pluses and minuses I quess.
/ Trouble with Home LED lights #11
Many of the early LED's were not UL certified. Bought some GL-10's online to replace the halogens we had. Halogens got just so hot, I really did not like them. The early GL-10's I bought burned out fairly quickly (were not UL certified), but the ones we have now are much better and have been great so far. The CREE's I have sitting in the closet have the UL label on them.
After removing the old LED bulbs, they were a but different from my others. These are from Lights of America 11Watt 4100K and are UL listed. I picked up 2 new from Lowes that are 12W with 75W equivalent however with 800 lumen output. They are bright however they are a warm white (3000K) which I don't really like for the color, it looks yellow rather than warm white which it is supposed to be. I didn't see any other flood type light there, only PAR30 spot. I may return them and look for some more in the 4100K range.
/ Trouble with Home LED lights #13
My Cree's are clean. See my thread about that very thing
/ Trouble with Home LED lights #14
What amazes me is that replacing a bulb leads you into a maze of technical mumbo-jumbo and after 3 decades of trying nobody has really improved the common old incandescent bulb as far as user friendly light goes. We use the fairly new GE energy efficient type that only save about 30% but at least they have the same Omni-directional output and the same lumen output as the old bulbs. And they fit it the lamps. I don't find that they get any hotter than old fashion bulbs. And best of all for me they are simple to figure out.
gg
/ Trouble with Home LED lights #15
I've not gotten into LED bulbs yet! What has caused me pause is the wide range of prices. My inclination is "you get what you pay for". So the low priced ones are attractive and the high priced ones I just don't know if they are worth it.
How much to you need to spend to get a quality bulb?
/ Trouble with Home LED lights #16
I have been using Cree's, the price has been dropping, and I am satisfied with them. They seem to be clean RFI wise, They seem to work well, and they dang sure save money on electricity.
Cree 60W Equivalent Daylight A19 Dimmable LED Light Bulb with 4-Flow Filament Design-BA19-08050OMB-12DE26-3_1 - The Home Depot
/ Trouble with Home LED lights #17
Lets do a little cost analysis to see if Gary saved any money on his 31,000 hour period he used his LED bulbs.
I don't know what Gary paid for those bulbs 5 years ago, but I am going to suggest he paid about $25 each. LED bulbs cost a lot more back then.
So he got 31,000 hours out of them, that would be about 30 standard bulbs that he could have bought for about $0.50 each. So he is in the hole about $10.00 on the costs of the bulb by my way of thinking. Now only Gary can tell us how much trouble it would have been to change out those 30 standard 1000 hour bulbs and whether that would be worth anything to him, but so far he is $10.00 in the hole in buying the LED bulb.
Now lets figure out how much electricity Gary saved with the 12 watt usage 60 watt equivilant LED bulb.
First lets figure how much the 30 standard bulbs would have cost to run. Lets see, 60 watts is .06 Kilowatts X 31000 hours = 1860 KiloWatt Hours. Lets say Gary pays $0.10 per KiloWatt Hour. So Gary would have payed $186.00 to run the 60 watt incandescent bulbs that 31,000 hours.
Now lets figure the LED bulbs. Gary said they used 12 watts. Newer bulbs use a bit less, but that seems about right for bulbs of that era.
12 Watts is .012 Killowatts. X 31,000 hours = 372 KiloWatt Hours. X $0.10 per Kilowatt hour (guessing here as to what Gary pays, but I doubt he pays any less than this) = $37.20 for electricity for the LED bulb. Whoa now! that is a huge saving in electricity. $186.00 - $37.20 = $148.80 in electrical savings, and now subtract the $10.00 that the bulb cost over the incandescent bulbs yields an overall savings of $138.80
Multipy the $138.80 by how ever many of these bulbs Gary had, and we are talking some real money.. Note that if the cost of electricity is more than the 10 cents and the fact that a good Cree bulb is about $9 at Home Depot, and that the new bulbs are 10 watts consumption for 815 lumens of light and your savings will be even more. Anyway you figure it, LED bulbs can save a pot of money, if they are used much.
Gary please correct me if anything doesn't look right in the figures or assumptions.
/ Trouble with Home LED lights #18
James thanks for going thru that!
If those lights are within a heated area, the savings is less because more heat may have been purchased to offset the cooler lighting (lesser electrical heating). If he'da fell off the ladder changing one of those 60 bulbs, the savings is more.
Light bulbs used to be 2,000 hour. Industry changed to 1,000 hour and nobody noticed, or cared. But they doubled the cost of bulbs and the profit (and doubled the cost of fixture maintenance too). Industry can do the same with LEDs (over time) if they get together and plan it. Its a rich country, and there's substantial profit in moves like that, enough to counter any opposition. Same big companies that did it with incandescents can surely pull it off again as long as there is no govt intervention.
If people waste less energy with LED lighting the grid can serve more citizens and seeing as how the citizens often have to pay for grid upgrades this "can" translate into savings but maybe only for the investors.
A few years ago I bought a few cases of 14,000 hour bulbs for 25c each. Not sure what to do with them now that LEDs are cheaper. I must have about 100 14,000 hour bulbs. :shocked:
edit: A documentary claims that an international cartel was created many years ago wherein lightbulb producers organized to reduce bulb lifetime hours to 1000, in 1924! :shocked: Seems to me that when I was a kid they were 2,000 hours, and sometime in the last 30 years they dropped to 1,000. I could be wrong.
/ Trouble with Home LED lights #19
So far no complaints with the CREE bulbs I bought 3 years ago... did almost all the bulbs at Mom's and noticed a big drop in kWh usage.
As of yet... never replaced one...
We also pay about 25 cents average per kW...
On a side note...
Brother has a string of lights around the Christmas Tree Farm sales area... 60W equivalent and 200 on one string of lights... 2,200 Watts on one circuit with LED instead of 12,000 Watts and 6 circuits.
Not CREE bulbs... it's like daylight out there and he is looking into a dimmer...
/ Trouble with Home LED lights #20
I bought some Cree bulbs that felt sticky and noticed that they had a plastic coating on them.
Perhaps the coating is starting to turn dark?
90cummins
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
213063 (A64276)
213063 (A64276)
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
