Trigger Pulled (thank you)
/ Trigger Pulled (thank you) #1
jsduke
West Central Pa.
PT-425 (Former Kubota L3130 HST)
This has been a little delayed, you know life getting in the way sometimes. The 425 has been here for just about a month. I will try to post a pic or two. The process of ordering/paying and shipping was pretty much a breeze. Once we (the driver and I) realized that the reason she would not start was that the fuel tank was too low the rest was easy.
Before anyone asks: Kohler engine, 5 (w/teeth) and 10 cube buckets, blade with steel edge and wheels, pallet forks, mini hoe w/ thumb and utility grapple. Bar tires. Spare wheel/tire.
Have not had much time to use it but when I have it performed mostly as expected and sometimes better. Gradually acclimating to the steering (especially in reverse) characteristics. Really like the quick attach...does anybody not like it?
Have a possible issue but will post a separate thread.
Thanks to all TBNers who answered all my questions. Special thanks to Ernie in Bolivar for allowing me to test drive his 422 and gain from his experience.
/ Trigger Pulled (thank you) #3
good job...congrats......remember when I first got mine and almost took the deck post down going in reverse......lol.......nothing that a little seat time won't solve!........Jack
/ Trigger Pulled (thank you) #4
I put an air hose pass-through port in the side of my garage with the toothed rock bucket. ;)
Oh yeah...
When I first had my Kubota I was not used to the length of it. Had just enough confidence to really wheel it around. Was looking over my shoulder going in reverse, swung the front end around and put a nice letter slot in the steel garage trim with the bucket cutting edge...cutting edge indeed! 😖
/ Trigger Pulled (thank you) #6
I almost ran over my wife when I got my 422, trying to back it off the truck and not used to going in reverse. Congrats
/ Trigger Pulled (thank you) #7
Well I have the 10 cu bucket, forks and built my own grapple and others but there are only 2 things I wish I had but too expensive. I wish I had the stump grinder and I want to fabricate and build my own mini hoe. I just need info on how they fabricate the end where the bucket attaches. How long is the square pipe and is it 4 or 5 inch sq or other size. How long is the hydraulic cylinder needed for it and so forth. I have the materials or can aquire them.
I will try and get you those measurements and a close up pic too if I can CC.
I had considered the stump grinder as well but with my needs and some concerns over the PT unit, I will just rent a stand alone when I need it.
/ Trigger Pulled (thank you) #9
Sweeeet ....... ;)
CC,
Attached are some pics with measurements on them. The thumb is 12 5/8 long with a 5x7x1/4 plate welded on and another 5x7x1/4 plate loosely bolted to the welded plate for clamping on the arm of the Hoe. The cylinder measurements do not include the bolt/pin eyes.
Did the best I could with pics and measurements. Hope it helps you
/ Trigger Pulled (thank you) #13
My $0.02, Keep both feet on both pedals at all times. Someone here suggested that, and I got a lot better.
I've hit the barn, the garage, innumerable fences, and stumps. More than a few by backing up and not realizing how close I actually was.
All the best,
Peter
/ Trigger Pulled (thank you) #14
Yes to hitting things backing up. Plenty of trees in close quarters. I'm sure it's because the machine articulates and it's easy to lose track of where your rear end is, because the seat is attached to the front half of the machine and your body doesn't sense where the rear end is.
/ Trigger Pulled (thank you) #15
I have a lot of problems keeping track of where my back end is so was wondering about mounting mirrors somehow to the overhead canopy posts. Has anyone tried that? I tend to oversteer a lot
/ Trigger Pulled (thank you) #16
I've got a rear view mirror mounted in the canopy, a big convex one. Never use it. Backing up the PT is not backing up a car. I only use it to keep track of what is behind me when I am doing road maintenance (blocking neighbors).
/ Trigger Pulled (thank you) #19
I learned to keep both feet on the peddles on most cases, for better/faster control. Backing up for me usually, is looking back to see what's back there but i've clobbered a tree or two and made good use of the ROPs when a big limb crashed down on top of me.
/ Trigger Pulled (thank you) #20
Awesome pictures. :cool2: Thanks so much but it looks bigger in the videos. These pics are great to get me started on doing some fabrication.
GENERAC MOBILE PRODUCTS  MAGNUM LIGHT/WATER PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2021 Bobcat T66 Compact Track Loader Skid Steer (A66734)
2021 Bobcat T66...
2020 Bobcat T650 Compact Track Loader Skid Steer (A66734)
2020 Bobcat T650...
84" Smooth Shell Kit (A68134)
84" Smooth Shell...
PROPANE BOTTLES (A68842)
PROPANE BOTTLES...
