Trenching with a Kioti
   / Trenching with a Kioti #11
Tapatalk dislikes multiple attachments apparently
   / Trenching with a Kioti #12
Tractor mounted trenchers are PTO driven only. Need Hydrostat transmission and 1 rear remote. No one in Texas rents them that I know of
Why no one in Texas rents pto driven trencher? Too expensive?
Only gasoline engine driven trencher there?
   / Trenching with a Kioti #13
A friend has a Kioti with FEL and 3Pt; I'm guessing it's a CX but not sure.
This is for a Ground Source Heat pump which would need 3 ft+ depth.
Would he be better off to rent a 3pt hitch trencher, or a skidsteer attachment for the FEL?
The Kioti CX2510 has a 11.3 GPM pump.
I'd think a tractor with hydrostatic drive would have sufficient GPM, but I'm no expert.
I will reference Bradco Trenchers as they have the widest offering in the market with skidsteer and 3pt trenchers. They also have been making tractor mount trenchers for several decades. I have never seen a 3pt trencher for rent so I am not going to go into details on them, unless Op plans on buying a unit.
The smallest ss trencher 625 is 14-22 GPM and is available with up to a 48" boom.
The next smallest is the 640 and it is 14-24 GPM with up to a 60
The tubing for the lines on a Kioti CX2510 is most likely 3/8" and therefor they cannot flow the full 11.3 GPM, Also the tractor might not have enough fluid to handle the continuous hydraulic load. If the 3rd function line uses 3/8" body fittings were the loader attaches to the tractor like many in that class do they are only good for 8 GPM.
Page 3
Your likely to discover that one rents 3pt trenchers. Your friend is short on hydraulic flow so using the tractor with a skidsteer trencher to install the lines is not feasible. I hope that the data is useful in your decision process.
Also out of curiosity is he in WA or WV? It might make a difference in alternative recommendations.
   / Trenching with a Kioti #14
Be sure you verify the depth you need first.
   / Trenching with a Kioti #15
Those 11.3 GPM is the flow of both pumps (steering + implement pump) which are different circuits and I don't know why they list it like that in the spec sheet.
The CX2510 has 6.5 CC pump for the steering and a 10 CC pump for the implement circuit (loader, remotes and 3 pt). At the rated 2600RPM, the 10 CC pump puts out about 6.8 GPM, even less than that if we account that most gear pumps are about 90% efficient.
   / Trenching with a Kioti #16
Yep, your right only 6.86 gpm. Had to look at the owners manual. Thanks for the correction!
This makes the decision easier for OP. The tractor cannot do it with a skidsteer trencher.
   / Trenching with a Kioti #17
CUTs top out at 8-10 of hydraulic flow. Usually less, especially with hydraulic losses. At 2,500psi that's only 18hp as a best case scenario, probably more towards 10, maybe 15hp of usable power. That's pretty low to cut a trench 3' deep & 6" wide. The smaller push ones are usually 18", maybe 2' and only 3-4" wide.
   / Trenching with a Kioti #18
It has been a while, but I researched and calculated the horsepower of my Kubota L4060 hydraulic capability at 14hp. That was assuming 100% availability of the implement pump available with no losses.
2003 Big Tex 10PI...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
(12) TOPPING JARS (A58374)
(12) TOPPING JARS...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
MASSEY FERGUSON 39 - 2R FLEX PLANTER (A52708)
MASSEY FERGUSON 39...
