Trenching with a Kioti
/ Trenching with a Kioti #1
Up to the Axles
Bainbridge Island, WA
Kuboto L4600
A friend has a Kioti with FEL and 3Pt; I'm guessing it's a CX but not sure.
This is for a Ground Source Heat pump which would need 3 ft+ depth.
Would he be better off to rent a 3pt hitch trencher, or a skidsteer attachment for the FEL?
/ Trenching with a Kioti #2
Unlikely the Kioto is going to have adequate hydraulic flow to operate an ssqa trencher.
I think you should just rent one of the walk behind trenchers that are a dime a dozen at rental companies.
I trenched a power line last year to my pile barn with a Toro walk behind, and it took no time at all.
/ Trenching with a Kioti #3
Many Many of those have a max trench depth of 24-30", and that's with the trencher buried. If you really Need 36", a good sized ditchwitch, or a weekend with a JD-27 type hoe, 12" bucket, is likely the way to go.
/ Trenching with a Kioti #4
Also, not knowing anything really about geothermal, the system is pressurized, right, not gravity fed? Reason I ask, a trencher will not leave a level trencher bottom, for give you slope control, if that's needed.
Having trenched in too many thousand feet of 3" electrical duct with DitchWitch's, I know how much work it can be. I'd think a tractor with hydrostatic drive would have sufficient GPM, but I'm no expert.
It would be slow work with the Kioti's backhoe, and wider than we need/want. I built a "fang" for another friend's Kuboto that was as narrow as feasible [<3"] and it did a good job but was far slower than the DW.
A GSHP well loop is positive flow; slope is not an issue, but depth very much is.
/ Trenching with a Kioti #6
Also depends on soil type and time of the year. In my rocky soil you'd never get a trencher down 36”… never. The geo systems ive been around are 4 to 5 foot deep here.
/ Trenching with a Kioti #7
My poor man's trencher - and I know it's not really ideal - is using my pallet forks for trenching. I remove one fork and put the other as close to center as possible. I've dug a few hundred feet of 24" deep trenches this way, though I've seen others online who have gone deeper. A shorter fork would be ideal, mine are 42" so I take shallow bites to avoid bending anything. I'd love to find an old 24" fork just to use for this purpose. We have heavy clay here and only occasional rocks bigger than a softball.
A walk behind trencher would be the best solution. Faster and cleaner.
/ Trenching with a Kioti #8
I rented a trencher and dug about 1300 feet of trench 3' deep for my water line. That was about as deep as it would go. That was hard clay and rock soil, and I did it in one day. Laid 2" pipe in it the next day and had "city" water before dinner.
I'd assumed the 3-pt trencher would be PTO-driven; it takes a lot of hydraulics to equal that.
This is in eastern WV. Finding one will likely be a major challenge.
/ Trenching with a Kioti #10
L4060hstc. 40hp & 6 speed Kubota HST+ tranny is barely slow enough. A geared machine wouldn't be slow enough & a normal HST may not be as well.
Bradco 612 trencher I got off Craigslist, some propane company stopped using it for installs. 3' by 6" blade. Due to angles it would dig a trench a little under 30" if I recall.
I've done a several hundred yards on a couple projects with it. Projects are done & I haven't used it in a few years so I need to take it to an auction or sell it. I also have an in with an ISP plowing fiber in all over the area if I need to do any more trenching. It got the job done ok. Not that much more problematic than any other trencher, but a 3pt on a tractor isn't as well setup as a real trencher. A fraction of the price though.
/ Trenching with a Kioti #12
Tractor mounted trenchers are PTO driven only. Need Hydrostat transmission and 1 rear remote. No one in Texas rents them that I know of
Why no one in Texas rents pto driven trencher? Too expensive?
Only gasoline engine driven trencher there?
/ Trenching with a Kioti #13
The Kioti CX2510 has a 11.3 GPM pump.
I will reference Bradco Trenchers as they have the widest offering in the market with skidsteer and 3pt trenchers. They also have been making tractor mount trenchers for several decades. I have never seen a 3pt trencher for rent so I am not going to go into details on them, unless Op plans on buying a unit.
The smallest ss trencher 625 is 14-22 GPM and is available with up to a 48" boom.
The next smallest is the 640 and it is 14-24 GPM with up to a 60
The tubing for the lines on a Kioti CX2510 is most likely 3/8" and therefor they cannot flow the full 11.3 GPM, Also the tractor might not have enough fluid to handle the continuous hydraulic load. If the 3rd function line uses 3/8" body fittings were the loader attaches to the tractor like many in that class do they are only good for 8 GPM.
Page 3
Your likely to discover that one rents 3pt trenchers. Your friend is short on hydraulic flow so using the tractor with a skidsteer trencher to install the lines is not feasible. I hope that the data is useful in your decision process.
Also out of curiosity is he in WA or WV? It might make a difference in alternative recommendations.
/ Trenching with a Kioti #14
Be sure you verify the depth you need first.
/ Trenching with a Kioti #15
Those 11.3 GPM is the flow of both pumps (steering + implement pump) which are different circuits and I don't know why they list it like that in the spec sheet.
The CX2510 has 6.5 CC pump for the steering and a 10 CC pump for the implement circuit (loader, remotes and 3 pt). At the rated 2600RPM, the 10 CC pump puts out about 6.8 GPM, even less than that if we account that most gear pumps are about 90% efficient.
/ Trenching with a Kioti #16
Yep, your right only 6.86 gpm. Had to look at the owners manual. Thanks for the correction!
This makes the decision easier for OP. The tractor cannot do it with a skidsteer trencher.
/ Trenching with a Kioti #17
CUTs top out at 8-10 of hydraulic flow. Usually less, especially with hydraulic losses. At 2,500psi that's only 18hp as a best case scenario, probably more towards 10, maybe 15hp of usable power. That's pretty low to cut a trench 3' deep & 6" wide. The smaller push ones are usually 18", maybe 2' and only 3-4" wide.
/ Trenching with a Kioti #18
It has been a while, but I researched and calculated the horsepower of my Kubota L4060 hydraulic capability at 14hp. That was assuming 100% availability of the implement pump available with no losses.
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A61574)
2007 30ft. Regal...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A61574)
2012 18ft Gastron...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
